Just need to adapt the WiFi module on carrier board if want to have wireless connectivity
No, not seen yet.
Jetson TX2i is a Jetson TX2 SKU for industrial environments. The rugged design, small form factor and power envelope make the Jetson TX2i module ideal for high performance edge computing devices such as industrial robots, machine vision cameras and portable medical equipment. See this FAQ for a comparison between Jetson TX2 and Jetson TX2i.
I am trying to have wireless connectivity with the TX2i, after SEVERAL tries I don’t achieve to have internet using a wifi dongle → Ralink 5370 Wifi Dongle USB 2.0 Wireless 802.11n.
Already using the TX2 module in an application, but now need have customers who do not WiFi components anywhere in the solution. TX2i module does not have the WiFi chipset, correct? Problem is that if I move to the TX2i the cost is higher and will also need to redo some firmware. Is there instructions on how to remove the WiFi component (Broadcom BCM4354(Cypress CYW4354) Chip) from the TX2 module? Is there a way to get the TX2 without the WiFi component?
