TX2i Tests detailed documents
Hi guys,
I need to have a detailed test document for the JetsonTX2i.
For example:
We need to know while running those cycles what is the detected faulty device and the devices Qty.
In how many cycles did you get a faulty device and more.
Can you guys deliever it for us?
That’s what we can provide. The report table has listed the Reference Standards.
OK. Thanks
Another question regard the Jetson TX2i.
Is this the temp range (Storage temp -40 - 85 deg) that the module was tested/will be tested (Xavier industrial) for, an actual damage can be done to the module for lower storage temp (-54 deg)?
Can you elaborate please, our demands starts at storage temp of -54 deg
Thanks a lot, appreciate your prompt response!
The temp range listed is must. -54C is out of the range, please follow the guide strictly.
OK.
Can you please explain what are the differences between those 2 Jetson TX2i revisions?
I know there was EMMC module change to Micron but u believe it is not related to those revisions.
699-83489-000-300 vs 699-83489-000-301
From the EMMC change notification
Jetson TX2i 699-83489-0000-*** modules with suffix greater than or equal to 301 may include Samsung eMMC (KLMBG4GEUFB04Q053) or the original eMMC part. Each module has a 2D barcode which may be used to identify the 699 level part number.
Following the completion of this PCN, NVIDIA may ship a mix of 699-83489-0000-300 and 699-83489-0000-301 revisions for an extended period of time. "
That revisions are only related to some parts change which have no difference to customer to make design.
