We are designing a common carrier for TX1/TX2/TX2i for one of our product. We need help to identify the suitable standoff and screw part number required for heat spreader and module assembly. The board thickness is 2.54 mm.Can anyone please help?
Goutam
Hi, do you check this topic? [url]https://devtalk.nvidia.com/default/topic/1043390/?comment=5292881[/url]
Also you can check the module datasheet and thermal design guide in DLC for more info.
Thanks!! I referred to the module datasheet and thermal design guide, but couldn’t find any information about the screw part number.Does the screw on top of the module come along with the module? Is it different for TX2 and TX2i ( it looks different in the image of thermal design guide document). Is The screw that comes below the module i.e. from bottom side of the PCB same as that of the top screw? Can we get more information about the screw part numbers?
Goutam
All we can provide about this are in DLC, further more, you can choose the general screw based on the dimension info, e.g. as others did in this topic: [url]https://devtalk.nvidia.com/default/topic/1036471/?comment=5289780[/url]
For the TTP difference between TX2 and TX2i, please refer to the comparison doc: [url]http://developer.nvidia.com/embedded/dlc/jetson-tx2-series-modules-interface-comparison-and-migration[/url]
