Hi Nvidia,
Our custom AGX ORIN board doesn’t work, please help solve this problem.
We use Jetpack 6.2 source code. Whether we cross - connect the TX and RX pins or connect the two serial ports, serial communication fails.
The dts:
uarta: serial@3100000 {
compatible = "nvidia,tegra234-uart", "nvidia,tegra20-uart";
reg = <0x0 0x03100000 0x0 0x10000>;
interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&bpmp TEGRA234_CLK_UARTA>;
resets = <&bpmp TEGRA234_RESET_UARTA>;
status = "disabled";
uartb: serial@3110000 {
reg = <0x0 0x03110000 0x0 0x10000>;
interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&bpmp TEGRA234_CLK_UARTB>;
resets = <&bpmp TEGRA234_RESET_UARTB>;
uartd: serial@3130000 {
reg = <0x0 0x03130000 0x0 0x10000>;
interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&bpmp TEGRA234_CLK_UARTD>;
resets = <&bpmp TEGRA234_RESET_UARTD>;
uarte: serial@3140000 {
reg = <0x0 0x03140000 0x0 0x10000>;
interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&bpmp TEGRA234_CLK_UARTE>;
resets = <&bpmp TEGRA234_RESET_UARTE>;
dmas = <&gpcdma 20>, <&gpcdma 20>;
dma-names = "rx", "tx";
uarti: serial@31d0000 {
compatible = "arm,sbsa-uart";
reg = <0x0 0x31d0000 0x0 0x10000>;
interrupts = <GIC_SPI 285 IRQ_TYPE_LEVEL_HIGH>;
/* UARTA */
serial@3100000 {
reset-names = "serial";
status = "okay";
/* UARTB */
serial@3110000 {
status = "okay";
/* UARTD */
serial@3130000 {
status = "okay";
/* UARTE */
serial@3140000 {
status = "okay";
serial@31d0000 {
current-speed = <115200>;
//status = "okay";
The dmesg log:
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 nospectre_bhb video=efifb:off console=tty0 bl_prof_dataptr=2031616@0x102C610000 bl_prof_ro_ptr=65536@0x102C600000
[ 0.000578] printk: console [tty0] enabled
[ 0.277963] printk: console [ttyTCU0] enabled
[ 4.017373] printk: console [tty0]: printing thread started
[ 4.018014] printk: console [ttyTCU0]: printing thread started
[ 4.068357] 3100000.serial: ttyS1 at MMIO 0x3100000 (irq = 112, base_baud = 4250000) is a Tegra
[ 4.072662] 3110000.serial: ttyS2 at MMIO 0x3110000 (irq = 113, base_baud = 4250000) is a Tegra
[ 4.074752] 3130000.serial: ttyS0 at MMIO 0x3130000 (irq = 114, base_baud = 4250000) is a Tegra
[ 4.076223] 3140000.serial: ttyS3 at MMIO 0x3140000 (irq = 115, base_baud = 4250000) is a Tegra
[ 8.596101] systemd[1]: Created slice Slice /system/serial-getty.
pinctrl:
# cat /sys/kernel/debug/pinctrl/2430000.pinmux/pinconf-groups |grep uart
88 (uart2_tx_px4):
function=uartb
89 (uart2_rx_px5):
function=uartb
90 (uart2_rts_px6):
function=uartb
91 (uart2_cts_px7):
92 (uart5_tx_py5):
function=uarte
93 (uart5_rx_py6):
function=uarte
94 (uart5_rts_py7):
function=uarte
95 (uart5_cts_pz0):
120 (uart1_cts_pr5):
121 (uart1_rts_pr4):
function=uarta
122 (uart1_rx_pr3):
function=uarta
123 (uart1_tx_pr2):
function=uarta
125 (uart4_cts_ph6):
126 (uart4_rts_ph5):
function=uartd
127 (uart4_rx_ph4):
function=uartd
128 (uart4_tx_ph3):
function=uartd
