Hi there,
I have not been able to get my Nvidia GeForce RTX 3050 Ti to work on my new Lenovo Legion 5.
I am dual booting Windows 11 and Ubuntu 20.04, the windows driver works fine by default but I cannot seem to get anything going in Ubuntu.
Some outputs I’m getting after following multiple install methods and approaches, for multiple driver versions. I don’t think the driver is ever being loaded or run.
There is also an Intel card installed - which seems to be the primary GPU - perhaps this is my issue?
$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
$ uname -r
6.1.8-060108-generic
$ lspci -k | grep -A 2 -i "VGA"
00:02.0 VGA compatible controller: Intel Corporation Device 46a6 (rev 0c)
Subsystem: Lenovo Device 3ae6
Kernel driver in use: i915
01:00.0 VGA compatible controller: NVIDIA Corporation Device 25e0 (rev a1)
Subsystem: Lenovo Device 382f
Kernel modules: nvidiafb, nouveau
$ inxi -G
Graphics: Device-1: Intel driver: i915 v: kernel
Device-2: NVIDIA driver: N/A
Display: x11 server: X.Org 1.20.13 driver: N/A resolution: 2560x1600~165Hz
OpenGL: renderer: llvmpipe (LLVM 12.0.0 256 bits) v: 4.5 Mesa 21.2.6
$ whereis nvidia
nvidia: /usr/lib/x86_64-linux-gnu/nvidia /usr/lib/nvidia /usr/share/nvidia /usr/src/nvidia-525.78.01/nvidia
$ sudo modprobe nvidia
modprobe: FATAL: Module nvidia not found in directory /lib/modules/6.1.8-060108-generic
$ nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
(nvidia-settings:36556): GLib-GObject-CRITICAL **: 10:46:52.559: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 10:46:52.562: PRIME: No offloading required. Abort
** Message: 10:46:52.562: PRIME: is it supported? no
Secure boot is disabled.
I have uploaded a bug report.
nvidia-bug-report.log.gz (152.2 KB)
Please help if you can?
