Are you talking about the fan running for a few seconds then stopping for a few seconds and repeating? I see that and I think it’s due to the temperature at idle being right close to the lower trip points then going up when the GPU kicks in. I think the trip points need to be tweaked.
No, no. When booting using ACPI it doesn’t stop, never ever.
Odd about the SD card. I do see mine in both ACPI and DeviceTree mode. This is the SD card on the NX module right? Or are you using a production module with an external SD card? Technically you don’t need it to boot since the UEFI will boot from the NVMe (assuming you can get that to work). Actually, I never tried booting from the SD card so I’m not sure the UEFI will actually find it.
This is the SDCard on the NX module, yes. I think it’s a regression on kernel as I had no issues with this when using 5.11.12-300.fc34.aarch64, but no luck with 5.12.7-300.fc34.aarch64.
Which kernel are you using, by the way?
Okay, now, let’s take a look in the configuration:
ACPI is set:
| O/S Hardware Description Selection |
O/S Hardware Description <ACPI> Select the hardware
description that will
be exposed to the O/S.
| F9=Reset to Defaults F10=Save |
| ^v=Move Highlight <Enter>=Select Entry Esc=Exit |
UEFI Quick Boot is Disabled.
| NVIDIA Resource Configuration |
Enable/Disable UEFI
Enable UEFI Quick Boot <Disabled> full device
> PCIe Configuration enumeration.
And PCIe is Enabled:
| PCIe Configuration |
Enable/Disable PCIe's
Enable PCIe in OS <Enabled> ACPI Entry to be
exposed to the O/S.
NX has been turned off and when turned on again, the very same sad menu:
| Boot Manager |
Device Path :
Boot Manager Menu HD(1,MBR,0x327DB5C6,0x
800,0x12C000)/\EFI\fed
Fedora ora\shimaa64.efi
UEFI PXEv4 (MAC:48B02D2F7BD0)
UEFI PXEv6 (MAC:48B02D2F7BD0)
UEFI HTTPv4 (MAC:48B02D2F7BD0)
UEFI HTTPv6 (MAC:48B02D2F7BD0)
UEFI Shell
UEFI SD Device
Use the <^> and <v> keys to choose a boot option,
the <Enter> key to select a boot option, and the
<Esc> key to exit the Boot Manager Menu.
Seems that everything is in a way it’s supposed to work, right? Not sure what may be the difference here that makes it not work on my case.
