Unable to create Nvv4l2 Decoder, NvStreamMux, pgie, nvvidconv, nvosd: Error while running DeepStream 4.0.2 Python apps
I have downloaded the Python samples and done the rest of the setup for DeepStream 4.0.2. Now, when I’m trying to run these samples in terminal for either downloaded videos or RTSP streams, always get below error:
$ python3 deepstream_test_2.py samples/streams/sample_720p.h264
Output:
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
 Unable to create NvStreamMux
 Unable to create pgie
 Unable to create tracker
 Unable to make sgie1
 Unable to make sgie2
 Unable to make sgie3
 Unable to create nvvidconv
 Unable to create nvosd
Creating EGLSink
 Unable to create egl sink
Playing file samples/streams/sample_720p.h264
  File "deepstream_test_2.py", line 320, in <module>
    sys.exit(main(sys.argv))
  File "deepstream_test_2.py", line 211, in main
    streammux.set_property('width', 1920)
I tried to run ‘python3 deepstream_test_1.py rtsp://192.168.0.3:5554/front’, and output is same:
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file rtsp://192.168.0.3:5554/front
  File "deepstream_test_1.py", line 263, in <module>
  File "deepstream_test_1.py", line 196, in main
AttributeError: 'NoneType' object has no attribute 'set_property'
Here is my system configuration:
Ubuntu 18.04
Nvidia GPU: GeForce GTX 1050 Ti
Gstreamer 1.14.5
Nvidia Driver: 440
Cuda 10.2
TensorRT 7.0.0
CuDNN 7.6.5
TensorFlow 2.1.0
DeepStream 4.0
I will provide more details if required.
Any idea about this error?
Similar issue with this topic,
Hi @Amycao,
Yes, it is almost similar issue, occurred when I was doing trials with TensorRT and Tensorflow versions. I linked this in one of replies Deepstream-app: error while loading shared libraries: libnvinfer.so.6: cannot open shared object file + ubuntu 18.04 - #10 by archana
Thanks,
Archana
