I am using a Jetson Orin NX 16GB with JetPack 6.2 (Ubuntu 22.04.5 LTS) and CUDA 12.6. I have installed ROS 2 Humble following NVIDIA’s official guide, but I am facing an issue when trying to install Gazebo-related packages.
When I run the following command:
rosdep install --from-paths src --ignore-src -r -y
I get multiple errors stating that the required Gazebo packages cannot be found.
Error Output:
executing command [sudo -H apt-get install -y ros-humble-gazebo-ros]
E: Unable to locate package ros-humble-gazebo-ros
executing command [sudo -H apt-get install -y ros-humble-gazebo-ros-pkgs]
E: Unable to locate package ros-humble-gazebo-ros-pkgs
executing command [sudo -H apt-get install -y ros-humble-gazebo-plugins]
E: Unable to locate package ros-humble-gazebo-plugins
executing command [sudo -H apt-get install -y ros-humble-gazebo-ros2-control]
E: Unable to locate package ros-humble-gazebo-ros2-control
executing command [sudo -H apt-get install -y ros-humble-velodyne-gazebo-plugins]
E: Unable to locate package ros-humble-velodyne-gazebo-plugins
