Hi, I am trying to create a connection between ros2 foxy and Isaac Sim. I have established a connection for the most part. I am able to read data from ros2 topics, and I can publish data as well. However; for some reason, the articulation node does not move the joints although I see the command inputs are coming. You can find the USD file that I have created from the link below. I appreciate any help.
Looking at the joints limits, it looks like the limits are not right:
This is using PhysX SDK debug vis, that you can enable in the physics debug window (Window->Simulation->Physics->Debug). There you can enable the debug vis and step the simulation one frame.
If you select the joint, you can also see during authoring that the limits are not right probably:
Regards,
Ales
Related topics
| Joints movement not working when using articulation | 0 | 223 | July 11, 2024 | |
| Articulation Controller not working | 6 | 3666 | October 2, 2022 | |
| Issac sim-Articulation | 1 | 99 | January 9, 2026 | |
| Articulation Root only forwarding joint commands to some joints | 2 | 433 | June 12, 2024 | |
| Simulation disrespecting joint limits | 16 | 2325 | March 27, 2024 | |
| Issue of adding an articulation root in an existing USD file | 3 | 114 | March 6, 2026 | |
| Failed to query Articulation in python script | 9 | 243 | October 28, 2025 | |
| The joint gap btw ROS and Sim | 3 | 789 | March 1, 2023 | |
| Setting joint positions while sim is not running or paused | 5 | 4011 | December 4, 2023 | |
| Error when using ROS2PublishJointState: Prim is not an articulation | 1 | 162 | February 4, 2025 |
