Need help to get driveworks sample running. Any idea what can be the problem?
./src/drivenet/drivenet/sample_drivenet
[20-11-2018 16:32:30] Initialize DriveWorks SDK v1.2.400
[20-11-2018 16:32:30] Release build with GNU 4.8.5 from v1.2.0-rc11-0-ga7f5475
[20-11-2018 16:32:30] Platform: Detected Generic x86 Platform
[20-11-2018 16:32:30] TimeSource: monotonic epoch time offset is 1542723880220026
[20-11-2018 16:32:30] Platform: number of GPU devices detected 1
[20-11-2018 16:32:30] Platform: currently selected GPU device discrete ID 0
[20-11-2018 16:32:30] SDK: Resources mounted from /usr/local/driveworks-1.2/samples/../data/resources
[20-11-2018 16:32:30] SensorFactory::createSensor() -> camera.virtual, dla=0,dlaEngineNo=0,enableFoveal=0,precision=fp32,stopFrame=0,video=/usr/local/driveworks-1.2/samples/../data/samples/raw/rccb.raw
[20-11-2018 16:32:30] CameraVirtual: The recorded RAW video appears to be a version 2, which is no longer supported
[20-11-2018 16:32:30] CameraRAW: no seek table found at /usr/local/driveworks-1.2/samples/../data/samples/raw/rccb.raw.seek, seeking is not available.
Camera image: 1920x1208
Camera image with 1920x1208 at 30 FPS
[20-11-2018 16:32:31] DriveNet: Running in FP32 mode.
[20-11-2018 16:32:31] Added linear block of size 22118400
[20-11-2018 16:32:31] Added linear block of size 7372800
[20-11-2018 16:32:31] Added linear block of size 3225600
[20-11-2018 16:32:31] DataConditioner: Scale transformation has been configured with 0.003922.
[20-11-2018 16:32:31] DataConditioner: Split transformation has been enabled.
[20-11-2018 16:32:31] DataConditioner: Value subtract transformation has been configured with {0.00000, 0.00000, 0.00000}.
[20-11-2018 16:32:31] CUDA cask failure at execution for trt_maxwell_scudnn_128x64_relu_medium_nn_v1.
[20-11-2018 16:32:31] caskConvolutionLayer.cpp (195) - Cuda Error in execute: 48
nvidia-smi
Tue Nov 20 16:34:32 2018
| NVIDIA-SMI 396.37 Driver Version: 396.37 |
| 0 Quadro K2200 Off | 00000000:02:00.0 On | N/A |
| 42% 36C P8 1W / 39W | 201MiB / 4042MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1819 G /usr/lib/xorg/Xorg 152MiB |
| 0 4849 G compiz 41MiB |
| 0 5867 G /usr/lib/firefox/firefox 1MiB |
| 0 6059 G /usr/lib/firefox/firefox 1MiB |
nvcc -V
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Tue_Jun_12_23:07:04_CDT_2018
Cuda compilation tools, release 9.2, V9.2.148
./mnistCUDNN
cudnnGetVersion() : 7102 , CUDNN_VERSION from cudnn.h : 7301 (7.3.1)
Host compiler version : GCC 5.4.0
There are 1 CUDA capable devices on your machine :
device 0 : sms 5 Capabilities 5.0, SmClock 1124.0 Mhz, MemSize (Mb) 4042, MemClock 2505.0 Mhz, Ecc=0, boardGroupID=0
Using device 0
Testing single precision
Loading image data/one_28x28.pgm
Performing forward propagation ...
Testing cudnnGetConvolutionForwardAlgorithm ...
Fastest algorithm is Algo 1
Testing cudnnFindConvolutionForwardAlgorithm ...
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.022880 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.035488 time requiring 3464 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.044288 time requiring 57600 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.266592 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.421344 time requiring 203008 memory
Resulting weights from Softmax:
0.0000000 0.9999399 0.0000000 0.0000000 0.0000561 0.0000000 0.0000012 0.0000017 0.0000010 0.0000000
Loading image data/three_28x28.pgm
0.0000000 0.0000000 0.0000000 0.9999288 0.0000000 0.0000711 0.0000000 0.0000000 0.0000000 0.0000000
Loading image data/five_28x28.pgm
0.0000000 0.0000008 0.0000000 0.0000002 0.0000000 0.9999820 0.0000154 0.0000000 0.0000012 0.0000006
Result of classification: 1 3 5
Test passed!
Testing half precision (math in single precision)
^^^^ CUDNN_STATUS_SUCCESS for Algo 0: 0.023424 time requiring 0 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 1: 0.031360 time requiring 3464 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 2: 0.040128 time requiring 28800 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 7: 0.263808 time requiring 2057744 memory
^^^^ CUDNN_STATUS_SUCCESS for Algo 5: 0.422848 time requiring 203008 memory
0.0000001 1.0000000 0.0000001 0.0000000 0.0000563 0.0000001 0.0000012 0.0000017 0.0000010 0.0000001
0.0000000 0.0000000 0.0000000 1.0000000 0.0000000 0.0000714 0.0000000 0.0000000 0.0000000 0.0000000
0.0000000 0.0000008 0.0000000 0.0000002 0.0000000 1.0000000 0.0000154 0.0000000 0.0000012 0.0000006
Test passed!
