Hi
when i try to login in order to use courses, it asks me to accept Eula and then when i click on accept, it returns back to login page again!
Hi @Bahman
I have forwarded this issue to the DLI team to investigate.
Thanks for your patience,
Tom
Hi @Bahman can you please provide a screenshot of the last page you see before you get redirected to the login page so I can try to help resolve this for you?
Hi @tdahlin,
When i enter my email address and password, this is the last page I see:
And clicking accept returns you to which page exactly? The one you enter your email address on?
What page are you visiting originally to try to login at? Are you going through https://courses.nvidia.com/join or courses.nvidia.com/dashboard to login?
both is same really, there is no difference. it doesnt let me to get into account!
@tdahlin
^ that one is my account as well. i cant login with both accounts! no matter which link i use!
@Bahman
Have you tried logging in using an in-cognito tab already? Sometimes browser plugins will cause issues by blocking or changing elements, and using an in-cognito tab can help with this.
Thanks so much, yeah incognito tap did it!! I appreciate it!
Glad to hear that worked! If using an in-cognito tab resolved the issue for you, there are a few things you can try to get it to work when you are not using an in-cognito tab:
- Clear your cache and cookies. Occasionally, due to the complex account systems that we have, your session can end up in a weird state that can cause unexpected behavior, and clearing your cookies and cache can help.
- Experiment with disabling and enabling browser extensions until it works. Usually, if a browser extension is causing a problem like this, it’s a privacy-focused plugin that’s being a little too aggressive. You should be able to disable these plugins on a per-site basis, so you shouldn’t need to uninstall anything.
Hi again, I tried everything you said but I can only login via incognito tab. I have tried already 3 different PCs, but all have same behaviour! But It’s ok, I can access to the course with that trick! Thank you for everything!
