Uninstall pip3 pip and all packages
Hi, I am using AGX with CUDA 10, I am getting errors with sudo pip3 install imagecodecs
WARNING: The directory '/home/agx/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
Collecting imagecodecs
  Downloading imagecodecs-2020.5.30.tar.gz (9.0 MB)
     |████████████████████████████████| 9.0 MB 2.1 MB/s
  Preparing metadata (setup.py) ... error
  ERROR: Command errored out with exit status -4:
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_be079ff606774eb5803188940b533978/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_be079ff606774eb5803188940b533978/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-g81po5df
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_be079ff606774eb5803188940b533978/
  Complete output (8 lines):
  running egg_info
  creating /tmp/pip-pip-egg-info-g81po5df/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-g81po5df/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-g81po5df/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-g81po5df/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-g81po5df/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-g81po5df/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-g81po5df/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/82/15/4b79e05aa490b9ee3598cf4686615ce941b4a0b442023da7862f16e097cd/imagecodecs-2020.5.30.tar.gz#sha256=c8c776922d3a60824d8d3d31ba674a250d1b4d429e81349b5c88c34d4353ddb5 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=3.6). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2020.2.18.tar.gz (8.8 MB)
     |████████████████████████████████| 8.8 MB 10.1 MB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_438032bc73bb45c792cd11374c82f159/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_438032bc73bb45c792cd11374c82f159/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-xtbmlc4v
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_438032bc73bb45c792cd11374c82f159/
  running egg_info
  creating /tmp/pip-pip-egg-info-xtbmlc4v/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-xtbmlc4v/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-xtbmlc4v/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-xtbmlc4v/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-xtbmlc4v/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-xtbmlc4v/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-xtbmlc4v/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/75/95/3699360d15e5e5d450bbd16ea554fb185117947e76fc772078c4f59ae1c1/imagecodecs-2020.2.18.tar.gz#sha256=c019b19438dff31365fee3002b438992c16bc9955a036f466c600d80699cb5a2 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=3.6). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2020.1.31.tar.gz (8.6 MB)
     |████████████████████████████████| 8.6 MB 3.3 MB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_efaa790c8ed943cf8c9af12c85d591e7/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_efaa790c8ed943cf8c9af12c85d591e7/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-6ivm5gc6
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_efaa790c8ed943cf8c9af12c85d591e7/
  running egg_info
  creating /tmp/pip-pip-egg-info-6ivm5gc6/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-6ivm5gc6/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-6ivm5gc6/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-6ivm5gc6/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-6ivm5gc6/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-6ivm5gc6/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-6ivm5gc6/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/fc/af/995f3fff6709bfad90ee211dbbbf0c1c8b99ed4bbc640bae47cb2e5ffbfa/imagecodecs-2020.1.31.tar.gz#sha256=2e093bec9dc136818b9e9bf48231c142ee403fd9b6f6d2a5a8b9fbfd77002a3a (from https://pypi.org/simple/imagecodecs/) (requires-python:>=3.6). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2019.12.31.tar.gz (3.5 MB)
     |████████████████████████████████| 3.5 MB 6.0 MB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_a0aa639b48ea4c6d841c7f044f7d402e/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_a0aa639b48ea4c6d841c7f044f7d402e/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-3ss2ntzp
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_a0aa639b48ea4c6d841c7f044f7d402e/
  running egg_info
  creating /tmp/pip-pip-egg-info-3ss2ntzp/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-3ss2ntzp/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-3ss2ntzp/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-3ss2ntzp/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-3ss2ntzp/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-3ss2ntzp/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-3ss2ntzp/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/f0/a9/3667634dd47639ddb274df4e07a84d97f78d7616b32dc71d370ce74aa00b/imagecodecs-2019.12.31.tar.gz#sha256=e286041d6fd3ebb9158322fb2c0df12c1c6a4e6d1e0e7a25c585f91428fe6d22 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2019.12.16.tar.gz (3.5 MB)
     |████████████████████████████████| 3.5 MB 18.9 MB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_3f14e4f9bd8847c8a8872f338fa93dcb/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_3f14e4f9bd8847c8a8872f338fa93dcb/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-six11xe5
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_3f14e4f9bd8847c8a8872f338fa93dcb/
  running egg_info
  creating /tmp/pip-pip-egg-info-six11xe5/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-six11xe5/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-six11xe5/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-six11xe5/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-six11xe5/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-six11xe5/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-six11xe5/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/3f/4d/84db16973afaed8b5a4374290e5f542ee960ea6f8f69903bfc804742d387/imagecodecs-2019.12.16.tar.gz#sha256=f8396f5531428411f4499cb37810470ac9a5eeb821d7c3c65a3b2c73963a3c5a (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2019.12.10.tar.gz (6.8 MB)
     |████████████████████████████████| 6.8 MB 209 kB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_19227eb5a6f4494c9ae2d7c9cefc3ecd/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_19227eb5a6f4494c9ae2d7c9cefc3ecd/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-j50oyi3l
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_19227eb5a6f4494c9ae2d7c9cefc3ecd/
  running egg_info
  creating /tmp/pip-pip-egg-info-j50oyi3l/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-j50oyi3l/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-j50oyi3l/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-j50oyi3l/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-j50oyi3l/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-j50oyi3l/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-j50oyi3l/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/d1/75/db36c21c1e708467cf7b1e881047e0bd5e745973d6862aedc1a34cc4cd56/imagecodecs-2019.12.10.tar.gz#sha256=d0f8411a82309cf373093b76a16a89404bdde8e38efabf0d9389a466ffd3e9d3 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2019.12.3.tar.gz (6.6 MB)
     |████████████████████████████████| 6.6 MB 6.6 MB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_e6771ad39a994a17bd2aab05edec40aa/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_e6771ad39a994a17bd2aab05edec40aa/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-bkzdkecc
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_e6771ad39a994a17bd2aab05edec40aa/
  running egg_info
  creating /tmp/pip-pip-egg-info-bkzdkecc/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-bkzdkecc/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-bkzdkecc/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-bkzdkecc/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-bkzdkecc/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-bkzdkecc/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-bkzdkecc/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/1e/d0/afabf5f5d7da0f9d7584ce6c4ae7ba42a05f8a833b32bcbf3a14a26cc689/imagecodecs-2019.12.3.tar.gz#sha256=28b39cee25e9c865a1f3915a7801ff5fd5aed86a6f3885b09ce2926ea40eef4f (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2019.11.28.tar.gz (6.5 MB)
     |████████████████████████████████| 6.5 MB 1.8 MB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_d0e176a99c9c4617bcc3e7961b696998/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_d0e176a99c9c4617bcc3e7961b696998/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-hpuis5ze
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_d0e176a99c9c4617bcc3e7961b696998/
  running egg_info
  creating /tmp/pip-pip-egg-info-hpuis5ze/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-hpuis5ze/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-hpuis5ze/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-hpuis5ze/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-hpuis5ze/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-hpuis5ze/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-hpuis5ze/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/b6/ad/0a79611ceef6d2350654b24c05269042bd4d16331dee6974ca4fc263e151/imagecodecs-2019.11.28.tar.gz#sha256=5dafd64527001ab1ab1833076d725cb326c93be4fe1850574391c8226c741580 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2019.11.18.tar.gz (6.5 MB)
     |████████████████████████████████| 6.5 MB 8.2 MB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_59bac54d2ddc4f14aaecde4dd130292f/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_59bac54d2ddc4f14aaecde4dd130292f/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-wzxbhhhs
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_59bac54d2ddc4f14aaecde4dd130292f/
  running egg_info
  creating /tmp/pip-pip-egg-info-wzxbhhhs/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-wzxbhhhs/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-wzxbhhhs/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-wzxbhhhs/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-wzxbhhhs/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-wzxbhhhs/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-wzxbhhhs/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/1b/fb/dcfb8d321ce6a1fdb55b4046d47cdc0b5d52c3d289aa1a7371d95596bcf7/imagecodecs-2019.11.18.tar.gz#sha256=037e3fde4592fffdb4b8235170180d0d0ba01e4640d9660360dcc62f062e2bd1 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2019.11.5.tar.gz (6.5 MB)
     |████████████████████████████████| 6.5 MB 1.5 MB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_334b55c4303a4be0880a1d7a87f7f821/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_334b55c4303a4be0880a1d7a87f7f821/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-54wxnaa4
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_334b55c4303a4be0880a1d7a87f7f821/
  running egg_info
  creating /tmp/pip-pip-egg-info-54wxnaa4/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-54wxnaa4/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-54wxnaa4/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-54wxnaa4/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-54wxnaa4/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-54wxnaa4/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-54wxnaa4/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/2b/3e/8a5a9e2e6043de6af39f050fd49cfc9b6463aa0afff792ba94ed4648d9a0/imagecodecs-2019.11.5.tar.gz#sha256=6e3464a2df3f3fc0d9895f4b510326fae2c6ce854bc887b00bad49620f5cae47 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2019.5.22.tar.gz (6.5 MB)
     |████████████████████████████████| 6.5 MB 324 kB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_abccd49771504aaaa9bcc367be21638a/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_abccd49771504aaaa9bcc367be21638a/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-821vswih
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_abccd49771504aaaa9bcc367be21638a/
  running egg_info
  creating /tmp/pip-pip-egg-info-821vswih/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-821vswih/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-821vswih/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-821vswih/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-821vswih/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-821vswih/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-821vswih/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/cc/46/665339ad16e9f05a96113b13a799d246fb27aef635426599edb962032e5b/imagecodecs-2019.5.22.tar.gz#sha256=7cd689549b41dc979fed1a26e668a080e67b276b029d179ae3a9eb27a0187719 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2019.4.20.tar.gz (3.2 MB)
     |████████████████████████████████| 3.2 MB 47 kB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_ec738f1a0a4f443fa66de42e308c319f/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_ec738f1a0a4f443fa66de42e308c319f/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-jaxx7m2y
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_ec738f1a0a4f443fa66de42e308c319f/
  running egg_info
  creating /tmp/pip-pip-egg-info-jaxx7m2y/imagecodecs.egg-info
  writing /tmp/pip-pip-egg-info-jaxx7m2y/imagecodecs.egg-info/PKG-INFO
  writing dependency_links to /tmp/pip-pip-egg-info-jaxx7m2y/imagecodecs.egg-info/dependency_links.txt
  writing entry points to /tmp/pip-pip-egg-info-jaxx7m2y/imagecodecs.egg-info/entry_points.txt
  writing requirements to /tmp/pip-pip-egg-info-jaxx7m2y/imagecodecs.egg-info/requires.txt
  writing top-level names to /tmp/pip-pip-egg-info-jaxx7m2y/imagecodecs.egg-info/top_level.txt
  writing manifest file '/tmp/pip-pip-egg-info-jaxx7m2y/imagecodecs.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/62/2c/c29eacf5606cb9a6c2237c9ed38696f4b830dab7841668617d1b0da6562f/imagecodecs-2019.4.20.tar.gz#sha256=095fb9f716717c4e387d606e48c0ca8ac9a1650723dcc49d02499285e863d5c9 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2019.2.22.tar.gz (3.2 MB)
     |████████████████████████████████| 3.2 MB 3.2 MB/s
   command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-5747b8jh/imagecodecs_4e680f98fe36497bb8dcd44a69dc707d/setup.py'"'"'; __file__='"'"'/tmp/pip-install-5747b8jh/imagecodecs_4e680f98fe36497bb8dcd44a69dc707d/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-koqonfkh
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_4e680f98fe36497bb8dcd44a69dc707d/
  Complete output (0 lines):
WARNING: Discarding https://files.pythonhosted.org/packages/03/24/faaa28f92dea240438cb64d3c054b994e1a7e82074a4205c567173ef6ad7/imagecodecs-2019.2.22.tar.gz#sha256=9bc20ebd597b27ffc26d30a403af9b2fde67f053010eb22487ad48dbc2687df9 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
  Downloading imagecodecs-2019.2.20.tar.gz (3.0 MB)
     |████████████████████████████████| 3.0 MB 11.4 MB/s
  Installing build dependencies ... done
  Getting requirements to build wheel ... error
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpguh5brce
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_861852f2639348af8c984ae6ddf80947
WARNING: Discarding https://files.pythonhosted.org/packages/8e/64/3b839f8bf3c72be752b3a607f4b48109f41d895e3bf71e22de5f319c7050/imagecodecs-2019.2.20.tar.gz#sha256=4d0351e7ed8e21e6a0641d60f5424b9d6e7f17f16a02feee7f5e1fc49b6dda94 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpguh5brce Check the logs for full command output.
  Downloading imagecodecs-2019.2.2.tar.gz (3.0 MB)
     |████████████████████████████████| 3.0 MB 7.0 MB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmp7ia8v7hh
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_c1cc9378857442b5b242d1fbc28e7649
WARNING: Discarding https://files.pythonhosted.org/packages/26/0b/594554e0a855334165ebe69572f8bf25cde1257d65ef0725e63477788588/imagecodecs-2019.2.2.tar.gz#sha256=d808a4c8f51ceef1290c3cc58f9a2a1484d5a2e35eff4df86a853e20b29c615d (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmp7ia8v7hh Check the logs for full command output.
  Downloading imagecodecs-2019.1.20.tar.gz (3.0 MB)
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpkv529vo2
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_8b086ca1a55c4ae88ac409987f0415d8
WARNING: Discarding https://files.pythonhosted.org/packages/2e/60/9bba14c19e7a5261ea1e64f2a51e91c4d1fcd041dbac305c8f689ae619f0/imagecodecs-2019.1.20.tar.gz#sha256=ad3c57a021f56fb7491df38c92bd279751e524d1558704704137cb4d8c1f5fb4 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpkv529vo2 Check the logs for full command output.
  Downloading imagecodecs-2019.1.14.tar.gz (3.0 MB)
     |████████████████████████████████| 3.0 MB 1.6 MB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpjhu0znde
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_daddec3e99c34bbb86a8e71ecacf1f89
WARNING: Discarding https://files.pythonhosted.org/packages/ea/37/f8b1e28aa6245be4e78933487b8dab180e21e5380f46597da16b44472b01/imagecodecs-2019.1.14.tar.gz#sha256=9b30816a2c8fe8927c92fb895a5f84c661c435d11bd146e86877dddc00636801 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpjhu0znde Check the logs for full command output.
  Downloading imagecodecs-2019.1.1.tar.gz (2.9 MB)
     |████████████████████████████████| 2.9 MB 5.0 MB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpht677zp5
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_b5f2b7b5925847d09e2ab5a41c62786d
WARNING: Discarding https://files.pythonhosted.org/packages/82/af/5e8eb7f18800819c88b60e77fa2dac4ba6c7e404d9df906c592833f5075c/imagecodecs-2019.1.1.tar.gz#sha256=f6dcafb2e5b09989567823b378a5bad61ccb2d88d71cf34030ed11cbe5bbcf9c (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpht677zp5 Check the logs for full command output.
  Downloading imagecodecs-2018.12.16.tar.gz (2.9 MB)
     |████████████████████████████████| 2.9 MB 12.3 MB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpriz5bz04
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_b47a8cbcfc6544d79cfc781bf7adafbd
WARNING: Discarding https://files.pythonhosted.org/packages/e5/9c/bdd00af95b458b7f67894c20723741c9d91c2f448c92952bedddc6a197f7/imagecodecs-2018.12.16.tar.gz#sha256=0974dc198383f1239ef29a6b5e49a5e060aaf284b30974bd0ded24391a1d525d (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpriz5bz04 Check the logs for full command output.
  Downloading imagecodecs-2018.12.12.tar.gz (2.9 MB)
     |████████████████████████████████| 2.9 MB 9.9 MB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpij3xoiuu
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_c45cb5d1da384f57ac00415cf453eecd
WARNING: Discarding https://files.pythonhosted.org/packages/a9/0e/2f62ff3390b741be546376c5ac05253453c251a1a485f6ca959172bd76c8/imagecodecs-2018.12.12.tar.gz#sha256=8e3a80e9cf33e6410420610453662a5e30e89221572a35b8c7d8574bfebd0232 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpij3xoiuu Check the logs for full command output.
  Downloading imagecodecs-2018.12.1.tar.gz (2.9 MB)
     |████████████████████████████████| 2.9 MB 8.3 MB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpbf2xn8ws
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_3a8183c7f0ab4091a6b1830a073b73fc
WARNING: Discarding https://files.pythonhosted.org/packages/ae/41/0d864345a789d559ea28e02dac5f4e587a4c7b6884cd5826e50ea2fe2264/imagecodecs-2018.12.1.tar.gz#sha256=563bfeec8ec8517166f07ca4990d046824f4a17a1dfec15f33a8bc73ff1fdbcb (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpbf2xn8ws Check the logs for full command output.
  Downloading imagecodecs-2018.11.8.tar.gz (2.9 MB)
     |████████████████████████████████| 2.9 MB 9.5 MB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmp356t4p8y
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_9495ca1864964fa892fb85b6c2cc672e
WARNING: Discarding https://files.pythonhosted.org/packages/96/11/b1c569a913e994b2a9043e61263c20005a51a68b5d8f85028af123cfa79b/imagecodecs-2018.11.8.tar.gz#sha256=20f70b7ba7b45a2bb8aa06734a7aafdf4b22462515cf5a7473c3dcd0707d01bc (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmp356t4p8y Check the logs for full command output.
  Downloading imagecodecs-2018.10.30.tar.gz (2.9 MB)
     |████████████████████████████████| 2.9 MB 6.0 MB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpr1opzvx1
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_8258ec7d28184eb299efd27f072c6f83
WARNING: Discarding https://files.pythonhosted.org/packages/53/5f/571690b63e97788a48ddb485936f777d2f100a1441864b826e93db33d0e2/imagecodecs-2018.10.30.tar.gz#sha256=ca287985ad0c2a19696e2a97fa524cb467dbbeadc3eda107e595f670b361c451 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpr1opzvx1 Check the logs for full command output.
  Downloading imagecodecs-2018.10.28.tar.gz (2.8 MB)
     |████████████████████████████████| 2.8 MB 8.8 MB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpwu0yvzgd
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_a384e4e61865415997e09cc02d008325
WARNING: Discarding https://files.pythonhosted.org/packages/fa/02/6f7c4e4fb9b37aa5bb7dbd8ba40a3f9b6f01d00f07db8546f737a42bd72f/imagecodecs-2018.10.28.tar.gz#sha256=6c5d4707b59af811cae8a9707579f3ee33f768616b889407d86fe15eb6cdbeba (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpwu0yvzgd Check the logs for full command output.
  Downloading imagecodecs-2018.10.22.tar.gz (2.0 MB)
     |████████████████████████████████| 2.0 MB 956 kB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpycrgupft
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_7f8d3fbd487249a9bdf296963fa1c405
WARNING: Discarding https://files.pythonhosted.org/packages/23/c0/65f2def041099ff4240d5077bdab15fe2fcac585655b1f48ef7f4f8e88ef/imagecodecs-2018.10.22.tar.gz#sha256=1786a689a712519f3df862992fcaa31fd8e74538a1371514cc26447116d88d31 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpycrgupft Check the logs for full command output.
  Downloading imagecodecs-2018.10.21.tar.gz (2.0 MB)
     |████████████████████████████████| 2.0 MB 54 kB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpnh6wvsc4
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_9e3be93628fe4ed289178eae2e71516e
WARNING: Discarding https://files.pythonhosted.org/packages/a6/66/77fea1d5574cd0e8eb386633b8fe25943e8081183a8ad58e3b0ea978d074/imagecodecs-2018.10.21.tar.gz#sha256=38e4852a2b890746ddb3a0399416bee69fb588d932c97e3a3513d3861f6d422f (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpnh6wvsc4 Check the logs for full command output.
  Downloading imagecodecs-2018.10.18.tar.gz (1.5 MB)
     |████████████████████████████████| 1.5 MB 3.2 MB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmp82z08ywx
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_2983a291ea4a4419a38ef1b842c05a4c
WARNING: Discarding https://files.pythonhosted.org/packages/fc/36/9a42f393fc0fb1aa4177e635eefbf369aee627aa0f3d9180af4f0241d71f/imagecodecs-2018.10.18.tar.gz#sha256=ef7d4b7b8f6dbceb75f0aa5b94a07687e96ad090aacc0b824222926736d4e2e8 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmp82z08ywx Check the logs for full command output.
  Downloading imagecodecs-2018.10.17.tar.gz (1.5 MB)
     |████████████████████████████████| 1.5 MB 5.5 MB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpv36t6j9j
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_2287478a50cf468188d0c27e1fc97228
WARNING: Discarding https://files.pythonhosted.org/packages/df/1d/b7bc692a7c4411a609acf20c7a145327d6a8e5886637c057755aebe1059f/imagecodecs-2018.10.17.tar.gz#sha256=b8e9b1b3065a7926fc475c069a0cd9ce6fc6de3f44d7e9369235a503be80bec8 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpv36t6j9j Check the logs for full command output.
  Downloading imagecodecs-2018.10.10.tar.gz (996 kB)
     |████████████████████████████████| 996 kB 578 kB/s
   command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpq14kx__u
       cwd: /tmp/pip-install-5747b8jh/imagecodecs_77a703a147464de19ae29251ab2ebb76
WARNING: Discarding https://files.pythonhosted.org/packages/fa/c6/03f295d4a7f963009a7abb72315d6cd0e1f5d6759d4f7acc6596786bfb1c/imagecodecs-2018.10.10.tar.gz#sha256=b4c1d6e691848e204f79e8f13bcfd2a0d410b27fb6d2bf7a941a128bff8a4097 (from https://pypi.org/simple/imagecodecs/) (requires-python:>=2.7). Command errored out with exit status -4: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/in_process/_in_process.py get_requires_for_build_wheel /tmp/tmpq14kx__u Check the logs for full command output.
ERROR: Could not find a version that satisfies the requirement imagecodecs (from versions: 2018.10.10, 2018.10.17, 2018.10.18, 2018.10.21, 2018.10.22, 2018.10.28, 2018.10.30, 2018.11.8, 2018.12.1, 2018.12.12, 2018.12.16, 2019.1.1, 2019.1.14, 2019.1.20, 2019.2.2, 2019.2.20, 2019.2.22, 2019.4.20, 2019.5.22, 2019.11.5, 2019.11.18, 2019.11.28, 2019.12.3, 2019.12.10, 2019.12.16, 2019.12.31, 2020.1.31, 2020.2.18, 2020.5.30)
ERROR: No matching distribution found for imagecodecs
And figured it out to start over with a clean installation
This looks to be duplicate of
Errors when installing imagecodes and scikit-image - #3 by DaneLLL
Let’s continue in the topic.
Hi I followed those steps and that is how I got here
