I have installed the PGI (32bit-trial license) compiler on Fedora Core 5. It installs fine but complains that I have an unknown version of glibc (ERROR: unknown glibc version (2.4)). When I try to compile something I get:
einstein-[nikhil] 46) pgf90 test.f90
pgf90-Error-file with unknown suffix ignored: test.f90
when I try the -V option, it says it’s an unknown switch. I “which” command gives the proper executable:
einstein-[nikhil] 49) which pgf90
/usr/pgi/linux86/6.1/bin/pgf90
There are a few questions here on FC5. The installation is failing for most people, hence the compiler errors. We are actively working on it and should have support for FC5 and glibc 2.4 in our products soon.
Do you have created a patch in order to solve that problem ? I’m using Fedora Core 5, and I’d like to compile my programs with your compiler in 64 bits.
It’s most likely that your installed failed for some reason. What OS are you using? Did the installer give any error messages? What is the output of “pgcc -dryrun” and “/lib/libc.so.6”?
I’m using Linux 8.0. The installation was completed and it created a 15 day evaluation license. the output of “pgcc -dryrun” is:
[qalberto@localhost bin]$ pgcc -dryrun
pgcc-Fatal-unable to find any RC file
and the output of “/lib/libc.so.6” is:
[qalberto@localhost bin]$ /lib/libc.so.6
GNU C Library stable release version 2.3.2, by Roland McGrath et al.
Copyright (C) 2003 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
Compiled by GNU CC version 3.2.2 20030222 (Red Hat Linux 3.2.2-5).
Compiled on a Linux 2.4.20 system on 2003-03-13.
Available extensions:
GNU libio by Per Bothner
crypt add-on version 2.1 by Michael Glad and others
linuxthreads-0.10 by Xavier Leroy
BIND-8.2.3-T5B
libthread_db work sponsored by Alpha Processor Inc
NIS(YP)/NIS+ NSS modules 0.19 by Thorsten Kukuk
Thread-local storage support included.
Report bugs using the `glibcbug’ script to <bugs@gnu.org>.
