Compiling
I have just installed PGI and I followed right the installation notes.
I’m using the evaluation license.
I have tried to compile the example. The command exits immediately whit this error
pgf77-Error-file with unknown suffix ignored: fftpde.F
pgf77-Warning-Unknown switch: -o
… where do I get wrong?
many thanks
Hi serafini,
It’s most likely an install or environment issue. What is the output of the following commands? Also make sure your envoking the pgf77 found in your install directory (like /usr/pgi) not the one that’s in the installation package.
/lib/libc.so.6
uname -a
which pgf77
pgf77 -dryrun x.F
Thanks,
Mat
Thanks Mat,
I did not have installed gcc on my machine so the installation was not complete !!!
ciao e thanks
Serafini
