[URGENT] Jetson ORIN Flashing through SDK Manager - Payment Required
Hello there,
I recently tried flashing the Jetson ORIN development kit (P3730) through SDK Manager with Jetpack 5.1.1 and It failed with the following errors.
ERROR: CUDA Cross Compile Package on Host - host: 402 Payment Required [IP: 2600:9000:21b4:9200:e:f4d2:20c0:93a1 443]
15:34:48 ERROR: CUDA Cross Compile Package on Host - host: E: Failed to fetch https://dl.cloudsmith.io/public/balena/etcher/deb/ubuntu/dists/focal/InRelease 402 Payment Required [IP: 2600:9000:21b4:9200:e:f4d2:20c0:93a1 443]
15:34:48 ERROR: CUDA Cross Compile Package on Host - host: E: The repository ‘https://dl.cloudsmith.io/public/balena/etcher/deb/ubuntu focal InRelease’ is no longer signed.
15:34:53 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
15:34:57 ERROR: VPI on Host - host: |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
15:34:58 ERROR: VPI on Host - host: Err:6 https://dl.cloudsmith.io/public/balena/etcher/deb/ubuntu focal InRelease
15:34:58 ERROR: VPI on Host - host: 402 Payment Required [IP: 2600:9000:21b4:9200:e:f4d2:20c0:93a1 443]
15:35:00 ERROR: VPI on Host - host: E: Failed to fetch https://dl.cloudsmith.io/public/balena/etcher/deb/ubuntu/dists/focal/InRelease 402 Payment Required [IP: 2600:9000:21b4:9200:e:f4d2:20c0:93a1 443]
15:35:00 ERROR: VPI on Host - host: E: The repository 'https://dl.cloudsmith.io/public/balena/etcher/deb/ubuntu focal InRelease' is no longer signed.
15:35:00 ERROR: VPI on Host - host: Error: safe apt install failed: sudo apt-get update , exit code: 100, retry number: 1
15:35:11 ERROR: VPI on Host - host: Err:6 https://dl.cloudsmith.io/public/balena/etcher/deb/ubuntu focal InRelease
15:35:11 ERROR: VPI on Host - host: 402 Payment Required [IP: 2600:9000:21b4:9200:e:f4d2:20c0:93a1 443]
15:35:13 ERROR: VPI on Host - host: E: Failed to fetch https://dl.cloudsmith.io/public/balena/etcher/deb/ubuntu/dists/focal/InRelease 402 Payment Required [IP: 2600:9000:21b4:9200:e:f4d2:20c0:93a1 443]
15:35:13 ERROR: VPI on Host - host: E: The repository 'https://dl.cloudsmith.io/public/balena/etcher/deb/ubuntu focal InRelease' is no longer signed.
15:35:13 ERROR: VPI on Host - host: Error: safe apt install failed: sudo apt-get update , exit code: 100, retry number: 2
15:35:33 ERROR: VPI on Host - host: Err:6 https://dl.cloudsmith.io/public/balena/etcher/deb/ubuntu focal InRelease
15:35:33 ERROR: VPI on Host - host: 402 Payment Required [IP: 2600:9000:21b4:9200:e:f4d2:20c0:93a1 443]
15:35:35 ERROR: VPI on Host - host: E: Failed to fetch https://dl.cloudsmith.io/public/balena/etcher/deb/ubuntu/dists/focal/InRelease 402 Payment Required [IP: 2600:9000:21b4:9200:e:f4d2:20c0:93a1 443]
15:35:35 ERROR: VPI on Host - host: E: The repository 'https://dl.cloudsmith.io/public/balena/etcher/deb/ubuntu focal InRelease' is no longer signed.
I have also added the log here too.
Appreciate any support to successfully flash the device.
SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_AGX_Orin_modules_2023-06-13_15-33-03.zip (86.3 KB)
You can try to not install CUDA or VPI on your host first and just focus on flashing the board.
Flashing the board is like installing OS to the board… CUDA or VPI are not related to OS.
