How should I configure ovs so that it respects the system design?
Should I add some flows?
Do I have to set the type of some port in “patch” and connect it to other ports?
How do I connect SF0 and SF1 to URL filter APP?
My current ovs configuration:
ubuntu@localhost:~$ sudo ovs-vsctl show
d3a1e07e-43a0-45a8-bbc4-da75864bc5bc
Bridge ovsbr2
Port p0
Interface p0
Port ovsbr2
Interface ovsbr2
type: internal
Port en3f0pf0sf5 -- SF1
Interface en3f0pf0sf5
Bridge ovsbr1
Port pf0hpf
Interface pf0hpf
Port ovsbr1
Interface ovsbr1
type: internal
Port en3f0pf0sf4 --SF0
Interface en3f0pf0sf4
ovs_version: "2.15.1"
sudo ovs-appctl dpctl/dump-flows
recirc_id(0),in_port(2),eth(src=04:3f:72:f4:43:6a,dst=ff:ff:ff:ff:ff:ff),eth_type(0x0800),ipv4(frag=no), packets:4, bytes:1368, used:1.830s, actions:3
ubuntu@localhost:~$ sudo ovs-ofctl dump-flows ovsbr1
cookie=0x0, duration=352795.033s, table=0, n_packets=293, n_bytes=25802, priority=0 actions=NORMAL
ubuntu@localhost:~$ sudo ovs-ofctl dump-flows ovsbr2
cookie=0x0, duration=352797.100s, table=0, n_packets=14766, n_bytes=4939164, priority=0 actions=NORMAL
