I am working on a USB Type C interface for a carrier board. I am planning on using a TI TUSB321 controller to handle the orientation detection and initialisation part of the protocol, and in their application note they recommend using a separate multiplexer to switch the USB SS RX and TX pairs, depending on the detected orientation. However I have noticed that the Jetson seems to have a suitable multiplexer built in, multiplexing the USB_SS0 and PEX1 lines to connect to the PEX lane 0. The relevant note in the OEM design guide states “PCIe interface #2 can be brought to the PEX1 pins, or USB 3.0 port #1 to the USB_SS0 pins on Jetson TX2 depending on
the setting of a multiplexor on the module. The selection is controlled by QSPI_IO2 configured as a GPIO.”
So my question is, can I simply connect one set of TX and RX lines to the PEX1 TX and RX connections, and the other to the standard USB_SS0 lines, and then use the QSPI_IO2 GPIO to switch between them based on detected orientation?
Many thanks.
