USB-C not working after reflashing of r36.4
Hi, i recently reflashed my Orinx NX 16GB Devkit with Jetson Linux r36.4. I completed the setup on the desktop, updated all packages and restarted. But since then no device does popup if i connect the USB-C port to a host machine, neither Windows nor macOS show any device connected to the USB port.
Any recommendations how I can trace down the issue?
Many Thanks
Hi paulober,
Please try connect USB cable to your host first before Orin NX boot up.
Connect USB cable to host → power on the Orin NX → check again.
You can refer to
Get Started With Jetson Nano Developer Kit
If the issue persists, try dumping the dmesg log and serial console log on Orin NX.
We also recommend connecting it to an Ubuntu host PC, as the verified use case is to connect the NX to an Ubuntu host.
Hi, that didn’t work but here is the dmesg output:
[    9.995269] pcieport 0008:00:00.0: AER: enabled with IRQ 188
[   10.171456] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[   10.172541] nvvrs-pseq-rtc nvvrs-pseq-rtc: setting system clock to 1970-01-01T00:00:30 UTC (30)
[   10.223968] tegra-adma 2930000.dma-controller: Tegra210 ADMA driver registered 32 channels
[   10.257497] r8168 0008:01:00.0: Adding to iommu group 50
[   10.257598] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[   10.257671] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[   10.274568] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[   10.276640] r8168  Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[   10.285124] r8168 0008:01:00.0 enP8p1s0: renamed from eth0
[   10.378242] tegra210-admaif 290f000.admaif: Adding to iommu group 52
[   12.252023] using random self ethernet address
[   12.252030] using random host ethernet address
[   12.289839] loop0: detected capacity change from 0 to 32768
[   12.344560] nv_nvsciipc_init.sh[674]: found /dev/nvsciipc
[   12.360134] nvsciipc: set_db start
[   12.360161] nvsciipc: set_db done
[   12.436518] enP8p1s0: 0xffff80000984d000, 48:b0:2d:f9:19:b1, IRQ 287
[   12.449898] Mass Storage Function, version: 2009/09/11
[   12.449906] LUN: removable file: (no medium)
[   12.454988] loop0: detected capacity change from 0 to 8
[   12.457614] using random self ethernet address
[   12.457620] using random host ethernet address
[   12.490762] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   12.495455] usb0: HOST MAC 6a:69:32:24:b0:04
[   12.495463] usb0: MAC 6a:69:32:24:b0:05
[   12.495769] usb1: HOST MAC 6a:69:32:24:b0:06
[   12.495771] usb1: MAC 6a:69:32:24:b0:07
[   12.498993] tegra-xudc 3550000.usb: EP 0 (type: ctrl, dir: out) enabled
[   12.511171] l4tbr0: port 1(usb0) entered blocking state
[   12.511189] l4tbr0: port 1(usb0) entered disabled state
[   12.511587] device usb0 entered promiscuous mode
[   12.519576] l4tbr0: port 2(usb1) entered blocking state
[   12.519595] l4tbr0: port 2(usb1) entered disabled state
[   12.519741] device usb1 entered promiscuous mode
[   12.528344] loop0: detected capacity change from 0 to 32768
[   12.570758] pstore: Using crash dump compression: deflate
[   12.570843] printk: console [ramoops-1]: printing thread started
[   12.570861] printk: console [ramoops-1] enabled
[   12.570864] pstore: Registered ramoops as persistent store backend
[   12.570865] ramoops: using 0x200000@0x4725f0000, ecc: 0
[   12.657023] IRQ230: set affinity failed(-22).
[   12.657070] IRQ287: set affinity failed(-22).
[   12.658135] psci: CPU4 killed (polled 0 ms)
[   12.740927] IRQ230: set affinity failed(-22).
[   12.740980] IRQ287: set affinity failed(-22).
[   12.741327] psci: CPU5 killed (polled 0 ms)
[   12.820918] IRQ230: set affinity failed(-22).
[   12.820970] IRQ287: set affinity failed(-22).
[   12.821188] psci: CPU6 killed (polled 0 ms)
[   12.901524] IRQ230: set affinity failed(-22).
[   12.901664] IRQ287: set affinity failed(-22).
[   12.901952] psci: CPU7 killed (polled 0 ms)
[   13.124408] nvgpu: 17000000.gpu                  gk20a_scale_init:541  [INFO]  enabled scaling for GPU
[   14.357682] zram: Added device: zram0
[   14.357949] zram: Added device: zram1
[   14.358438] zram: Added device: zram2
[   14.358653] zram: Added device: zram3
[   14.421886] zram0: detected capacity change from 0 to 4007832
[   14.435771] Adding 2003912k swap on /dev/zram0.  Priority:5 extents:1 across:2003912k SS
[   14.441669] zram1: detected capacity change from 0 to 4007832
[   14.450613] Adding 2003912k swap on /dev/zram1.  Priority:5 extents:1 across:2003912k SS
[   14.456169] zram2: detected capacity change from 0 to 4007832
[   14.465098] Adding 2003912k swap on /dev/zram2.  Priority:5 extents:1 across:2003912k SS
[   14.469805] zram3: detected capacity change from 0 to 4007832
[   14.484815] Adding 2003912k swap on /dev/zram3.  Priority:5 extents:1 across:2003912k SS
[   14.965279] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64  540.4.0  Release Build  (buildbrain@mobile-u64-5441-d8000)  Thu Sep 12 21:22:09 PDT 2024
[   14.972344] [drm] [nvidia-drm] [GPU ID 0x00020000] Loading driver
[   15.255696] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[   15.288896] [drm] Initialized nvidia-drm 0.0.0 20160202 for 13800000.display on minor 1
[   15.305336] nv_platform 13800000.display: [drm] Cannot find any crtc or sizes
[   16.589946] r8168: enP8p1s0: link up
[   16.590033] IPv6: ADDRCONF(NETDEV_CHANGE): enP8p1s0: link becomes ready
[   17.502162] rfkill: input handler disabled
I tried connecting to the serial console via UART but do not receive any output. I assume it may be disabled?
Also since the reflash, the Unit is constantly refreshing it’s IPv6 addresses on reboot.
Which original version of Jetson Linux do you use?
What is your use case for connecting a Type-C port to a Windows or Mac computer?
