USB-C problem in jetson orin
USB-C port in Jetson Orin Nx is not detected and jetson can not recognize the usb stick that is connected to usb-c. lsusb result also does not show the device in usb-c port. I am using Jetpack 5.1.4 and Jetson Orin nx 16G
have you tried with oher USB device to confirm the USB post is working?
Better clarifying if you are using NV devkit first. And in what situation that it could not be “detected”.
For example, in kernel or in recovery mode?
I am using development kit. The usb-c device is working with other objects such as laptop and there was no issue in the device. but when I checked with lsusb and lsmod | grep usb in jetson orin nx, no thing detected relevant to my usb-c device and also the small light of my usb stick is off which means the device is inactive when connected to the usb-c of jetson orin
Please dump out the dmesg when usb is connected on the board.
this is the result of “sudo dmesg | grep -i usb” when usb-c is connected
[ 1.399638] usbcore: registered new interface driver usbfs
[ 1.405134] usbcore: registered new interface driver hub
[ 1.410454] usbcore: registered new device driver usb
[ 3.936099] usbcore: registered new interface driver r8152
[ 3.941730] usbcore: registered new interface driver asix
[ 3.947276] usbcore: registered new interface driver ax88179_178a
[ 3.953534] usbcore: registered new interface driver cdc_ether
[ 3.959524] usbcore: registered new interface driver net1080
[ 3.965332] usbcore: registered new interface driver cdc_subset
[ 3.971409] usbcore: registered new interface driver zaurus
[ 3.977126] usbcore: registered new interface driver cdc_ncm
[ 3.982939] usbcore: registered new interface driver aqc111
[ 3.988771] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.005320] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 4.011652] usbcore: registered new interface driver uas
[ 4.017131] usbcore: registered new interface driver usb-storage
[ 4.035252] usbcore: registered new interface driver xpad
[ 5.849846] usbcore: registered new interface driver usbhid
[ 5.855574] usbhid: USB HID core driver
[ 6.265433] usbcore: registered new interface driver snd-usb-audio
[ 7.532190] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[ 7.541945] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.547518] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.556157] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 7.565776] tegra-xusb 3610000.xhci: irq 229, io mem 0x03610000
[ 7.572094] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.577652] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.585447] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.593101] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.601609] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.609043] usb usb1: Product: xHCI Host Controller
[ 7.614050] usb usb1: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[ 7.620337] usb usb1: SerialNumber: 3610000.xhci
[ 7.625899] hub 1-0:1.0: USB hub found
[ 7.634224] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.642737] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.650172] usb usb2: Product: xHCI Host Controller
[ 7.655186] usb usb2: Manufacturer: Linux 5.10.192-tegra xhci-hcd
[ 7.661467] usb usb2: SerialNumber: 3610000.xhci
[ 7.666783] hub 2-0:1.0: USB hub found
[ 7.908392] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 8.106989] usb 1-2: New USB device found, idVendor=2109, idProduct=2822, bcdDevice= 7.f3
[ 8.115413] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.122762] usb 1-2: Product: USB2.0 Hub
[ 8.127957] usb 1-2: Manufacturer: VIA Labs, Inc.
[ 8.133597] usb 1-2: SerialNumber: 000000001
[ 8.138995] hub 1-2:1.0: USB hub found
[ 8.247692] usb 2-1: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 8.355561] usb 2-1: New USB device found, idVendor=2109, idProduct=0822, bcdDevice= 7.f3
[ 8.363982] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.363983] usb 2-1: Product: USB3.1 Hub
[ 8.363985] usb 2-1: Manufacturer: VIA Labs, Inc.
[ 8.363986] usb 2-1: SerialNumber: 000000001
[ 8.416727] hub 2-1:1.0: USB hub found
[ 8.474992] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 8.634831] usb 1-3: New USB device found, idVendor=8087, idProduct=0032, bcdDevice= 0.00
[ 8.643248] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.900389] usb 1-2.2: new full-speed USB device number 4 using tegra-xusb
[ 9.069664] usb 1-2.2: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 9.078262] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.085778] usb 1-2.2: Product: USB Receiver
[ 9.090169] usb 1-2.2: Manufacturer: Logitech
[ 9.101635] input: Logitech USB Receiver as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:046D:C534.0001/input/input0
[ 9.172928] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-2.2/input0
[ 9.189750] input: Logitech USB Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C534.0002/input/input1
[ 9.203092] input: Logitech USB Receiver Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C534.0002/input/input2
[ 9.276638] input: Logitech USB Receiver System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C534.0002/input/input3
[ 9.290824] hid-generic 0003:046D:C534.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-2.2/input1
[ 9.432389] usb 1-2.3: new high-speed USB device number 5 using tegra-xusb
[ 9.643108] usb 1-2.3: New USB device found, idVendor=148f, idProduct=5370, bcdDevice= 1.01
[ 9.651695] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.651697] usb 1-2.3: Product: 802.11 n WLAN
[ 9.651698] usb 1-2.3: Manufacturer: Ralink
[ 9.651699] usb 1-2.3: SerialNumber: 1.0
[ 12.919652] fusb301 1-0025: failed to read device id, err : 0xffffff87
[ 12.928261] fusb301 1-0025: fusb301 not support
[ 12.934868] fusb301: probe of 1-0025 failed with error -22
[ 13.256475] usb 1-2.3: reset high-speed USB device number 5 using tegra-xusb
[ 13.272370] logitech-djreceiver 0003:046D:C534.0001: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-2.2/input0
[ 13.542013] logitech-djreceiver 0003:046D:C534.0002: hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-2.2/input1
[ 13.596564] usbcore: registered new interface driver rt2800usb
[ 13.603463] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input11
[ 13.603635] input: Logitech Wireless Keyboard PID:4023 Consumer Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input12
[ 13.603841] input: Logitech Wireless Keyboard PID:4023 System Control as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input13
[ 13.604031] hid-generic 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-3610000.xhci-2.2/input1:1
[ 13.605302] input: Logitech Wireless Mouse PID:4054 Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C534.0002/0003:046D:4054.0004/input/input18
[ 13.605502] hid-generic 0003:046D:4054.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4054] on usb-3610000.xhci-2.2/input1:2
[ 13.967254] input: Logitech Wireless Keyboard PID:4023 as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input22
[ 13.967459] logitech-hidpp-device 0003:046D:4023.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-3610000.xhci-2.2/input1:1
[ 14.019074] input: Logitech Wireless Mouse as /devices/platform/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C534.0002/0003:046D:4054.0004/input/input23
[ 14.019171] logitech-hidpp-device 0003:046D:4054.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-3610000.xhci-2.2/input1:2
[ 14.914073] usb0: HOST MAC d6:85:8e:3e:65:82
[ 14.914075] usb0: MAC d6:85:8e:3e:65:83
[ 14.923734] l4tbr0: port 2(usb0) entered blocking state
[ 14.923748] l4tbr0: port 2(usb0) entered disabled state
[ 14.923884] device usb0 entered promiscuous mode
I don’t need your “grep usb”. I need the full log.
And please do not copy and paste a log. Attach it as a file.
Ok this is the log file
dmesg.log (70.3 KB)
There are directly some errors that I can see from my side
[ 12.926756] cpu-throttle-alert cooling device registered.
[ 12.926847] gpu-throttle-alert cooling device registered.
[ 12.926916] cv0-throttle-alert cooling device registered.
[ 12.927115] cv1-throttle-alert cooling device registered.
[ 12.927330] r8168 0008:01:00.0: Adding to iommu group 10
[ 12.927355] cv2-throttle-alert cooling device registered.
[ 12.927579] soc0-throttle-alert cooling device registered.
[ 12.927627] r8168 Gigabit Ethernet driver 8.051.02.10m_pll-NAPI loaded
[ 12.927636] soc1-throttle-alert cooling device registered.
[ 12.927679] soc2-throttle-alert cooling device registered.
[ 12.927717] r8168 0008:01:00.0: enabling device (0000 → 0003)
[ 12.927751] hot-surface-alert cooling device registered.
[ 12.930426] nvadsp 2993000.adsp: Adding to iommu group 56
[ 12.934390] nvadsp 2993000.adsp: in probe()…
The type C usb controller driver directly gave you an error.
[ 0.000000] Linux version 5.10.192-tegra (jenkins@fafd8ddc663b) (aarch64-linux-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Thu Mar 7 15:50:49 CST 2024
Your kernel built time directly told that this is not pure kernel image provided by NVIDIA sdkmanager/Jetpack.
Thus, to clarify if this is hardware problem or software, could you reflash your whole board back to default NVIDIA image and check if that would work?
Actually I have flashed my nvidia via sdk manager to the jetpack 5.1.3. Do you mean again I need to re-flash it?
Your log obviously told me that this is not NVIDIA image from sdkmanager.
[ 0.002653] DTS File Name: /home/jenkins/agent/workspace/orin_nx_kernel_l4t-35.5.0-imx708/kernel/kernel-5.10/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0000-p3768-0000-a0.dts
[ 0.002659] DTB Build time: Mar 7 2024 15:57:46
The built time is 3/7 /2024. We didn’t release anything at that time.
And built location is not from our machine.
