We observed frame drops on our three USB cameras whenever Wi-Fi is enabled. The Wi-Fi module is connected via PCIe, while the cameras use USB interfaces.
We have attempted CPU core binding, core isolation, and scheduling priority tuning, yet none of these measures resolved the issue. this may not be a scheduling issue.
After enabling xhci_usb logs, we found that frames appear to be actively discarded by the USB hardware controller. Why does the PCIe Wi-Fi interfere with USB cameras?
The issue occurs consistently upon repeated testing. Please let me know what further information I need to collect.
Do you use Jetpack 7.2 r39.2? Would like to know if you observe the issue on latest Jetpack 7 release.
After upgrading to Jetpack 7.2 r39.2, the same problem occurs.
Do you use custom board or developer kit? One possible rootcause of the prints is signal quality of USB pins are not stable. We have done compliance test to our developer kit and it is supposed to have good signal integrity.
It has been verified via devkit testing that issues arise when using the FC64E PCIe Wi-Fi module. The problem disappears after replacing it with an RTL8852CE module. Why does the PCIe Wi-Fi adapter interfere with the USB camera?
Attempts we have made so far:
- Replaced with RTL8852CE Wi-Fi module, the issue disappeared.
- iperf test revealed worse performance.
- CPU core affinity binding, core isolation and scheduling priority tuning were applied, but the issue remains.
- Tested on Thor DevKit paired with Quectel FC64E, the issue persists.
- Upgraded to JetPack 7.2, the issue still exists.
- Disabled Wi-Fi power saving; frame loss rate dropped.
- Performed AP scanning only with command
sudo iw dev wlan0 scan, the issue persists.
- Configured UVC URB count = 50 and TRB segments = 32, the issue remains.
It looks to be high-frequency radio of WIFI triggering the issue. Please check if Quectel FC64E is well connected with antenna. And if the antenna can be far away from the developer kit.
