USB3.0 cable manual update voltage swing
usb camera open failed:
v4l2 demux error: dequeue error: No such device
tegra login: [17790.306381] usb usb2-port1: status 0203 change 0000 [17790.379681] usb 2-1-port2: status 0203 change 0001 [17790.487057] usb 2-1-port2: Devices connected to USB_SPEED_SUPER hubs are USB 3.0 or later, USB_SPEED_SUPER: 5, USB_SPEED_UNKNOWN: 0 [17790.589191] usb 2-1.2: udev->wusb: 0, USB_SPEED_SUPER: 5, udev->speed: 5, le16_to_cpu(udev->descriptor.bcdUSB): 0x300 [17790.590710] usb 2-1-port2: check for devices running slower than they could, udev->descriptor.bcdUSB: 0x300, le16_to_cpu(udev->descriptor.bcdUSB): 0x300, udev->speed: 5, USB_SPEED_FULL: 2 [17790.590719] usb 2-1-port2: Store the parent’s children[] pointer. At this point [17790.590724] usb 2-1-port2: We mustn’t add new devices if the parent hub has [17790.590728] usb 2-1-port2: Run it through the hoops (find a driver, etc) [17790.755555] tegra-xusb 3610000.usb: Stopped on No-op or Link TRB for slot 5 ep 6 [17790.755742] tegra-xusb 3610000.usb: Stopped on No-op or Link TRB for slot 5 ep 8 [17791.060095] usb 2-1-port2: usb phy notify connect, udev->speed: 5 [17791.060103] hub 2-1:1.0: else 0mA power budget left [17791.086677] tegra-xusb 3610000.usb: Stopped on Transfer TRB for slot 5 ep 6 [17791.112552] tegra-xusb 3610000.usb: Stopped on Transfer TRB for slot 5 ep 6 [17791.113425] tegra-xusb 3610000.usb: Stopped on Transfer TRB for slot 5 ep 6 [17791.113675] tegra-xusb 3610000.usb: Stopped on Transfer TRB for slot 5 ep 6 [17791.114806] tegra-xusb 3610000.usb: Stopped on Transfer TRB for slot 5 ep 6 [17791.115297] tegra-xusb 3610000.usb: Stopped on Transfer TRB for slot 5 ep 6 [17791.116052] tegra-xusb 3610000.usb: Stopped on Transfer TRB for slot 5 ep 6 [17791.222551] tegra-xusb 3610000.usb: Stopped on Transfer TRB for slot 5 ep 6 [17791.223298] tegra-xusb 3610000.usb: Stopped on Transfer TRB for slot 5 ep 6 [17793.570173] tegra-xusb 3610000.usb: Stopped on Transfer TRB for slot 2 ep 2 [17793.571090] tegra-xusb 3610000.usb: Stopped on No-op or Link TRB for slot 2 ep 0 vlc open dev/video0 failed error log: VLC media player 3.0.16 Vetinari (revision 3.0.13-8-g41878ff4f2) [0000aaaaf70c1590] main libvlc: Running vlc with the default interface. Use ‘cvlc’ to use vlc without interface. [0000aaaaf7156b60] main playlist: playlist is empty [0000ffff60001150] v4l2 demux error: dequeue error: No such device usb 3.0 error log: [17810.677845] usb usb2-port1: status 0263 change 0000 [17810.780191] usb 2-1-port2: status 0263 change 0000 [17811.419485] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.419505] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.419511] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.419515] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.419519] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.419523] tegra-xusb 3610000.usb: Miss service interval error for slot 5 ep 2, set skip flag [17811.419527] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.419530] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.440603] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.440613] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.440617] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.440621] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.440624] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.440627] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.440630] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.440633] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.508473] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.508487] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.508491] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.508494] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.508498] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.508502] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.508504] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.508506] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.593599] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.593612] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.593616] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.593619] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.593622] tegra-xusb 3610000.usb: Miss service interval error for slot 5 ep 2, set skip flag [17811.593626] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.593629] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.593632] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.600503] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.600518] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.600526] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.600533] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.600541] tegra-xusb 3610000.usb: Miss service interval error for slot 5 ep 2, set skip flag [17811.600549] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.600557] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.600564] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.648397] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.648411] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.712970] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.712981] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.712984] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.712985] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.712987] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.712988] tegra-xusb 3610000.usb: Miss service interval error for slot 5 ep 2, set skip flag [17811.712990] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.712992] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.760340] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.760354] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.760357] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.760360] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.760363] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.760366] tegra-xusb 3610000.usb: Miss service interval error for slot 5 ep 2, set skip flag [17811.760369] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.760372] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.761424] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.761434] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.761441] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.761448] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.761454] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.761460] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.761467] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.761471] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.806972] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.806980] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.806982] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.806984] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.806986] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.806988] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.806989] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.806991] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.870670] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.870679] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.870683] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD [17811.870687] tegra-xusb 3610000.usb: No Ping response error for slot 5 ep 2, Skip one Isoc TD
refer doc: Jetson-Orin-Nano-NX-Series-Modules-Tuning-Complinace-Guide_DA-11267-001v1.3.pdf
if manual voltage swing for USB3.0 as following sample command:
sudo echo on > /sys/bus/usb/devices/usb1/power/control
sudo echo on > /sys/bus/usb/devices/usb2/power/control
sudo devmem2 0x03610420 w 0x10340
sudo devmem2 0x03610430 w 0x10340
sudo devmem2 0x03610440 w 0x10340
usb3.0 camera plug in log:
[17790.590719] usb 2-1-port2: Store the parent’s children pointer. At this point
vlc open /dev/video0 error log:
usb 3.0 error log:
Looks like duplicate with topic 375081
Do you verify by v4l2-ctl--stream-mmap ?
