I’m using Omniverse to create a complicated scene. Currently, I partition the whole scene into different areas, and they are not relevant to each other.
Unfortunately, it’s quite slow to generate the areas one by one. And ideally, No data race will occur. So, I’m wondering if is it possible to use multiple threads in Omniverse so that I can boost the performance/speed of generation?
I check the topic Multi-threading in Omniverse extensions - Omniverse / Developer - NVIDIA Developer Forums
and the Pixar document Universal Scene Description: Threading Model and Performance Considerations (openusd.org).
If I understand correctly, I cannot write to the same stage from multiple threads. And the feasible way : “it is safe for different threads to write simultaneously to different stages”.
With this information, I tried to write a small ugly demo.
This is the code snippet without threads:
import omni
from pxr import Usd, UsdGeom, Sdf
import random
from datetime import datetime
now = datetime.now()
dt_str = now.strftime("_%Y_%m_%d__%H_%M_%S")
global_stage = omni.usd.get_context().get_stage()
def create_sphere(stage):
geom_xform = UsdGeom.Xform.Define(stage, '/Geom')
geom_prim = stage.GetPrimAtPath('/Geom')
sphere = UsdGeom.Sphere.Define(stage, '/Geom/sphere')
sphere_prim = stage.GetPrimAtPath('/Geom/sphere')
stage.SetDefaultPrim(geom_prim)
UsdGeom.XformCommonAPI(sphere_prim).SetTranslate((
random.randint(0, 10),
stage.GetRootLayer().Save()
return stage
stage_num = 10
def create_stage_with_sphere(index):
stage_path = f"./cache/Substage_{dt_str}_{index}.usd"
sub_stage = Usd.Stage.CreateNew(stage_path)
create_sphere(sub_stage)
# parallelize this
for i in range(stage_num):
create_stage_with_sphere(i)
prim_path = Sdf.Path(
"/World").AppendChild("Substage_{}".format(i))
sub_prim = global_stage.DefinePrim(prim_path, "Xform")
sub_prim.GetReferences().AddReference(
"./cache/Substage_{}_{}.usd".format(dt_str, i))
It works good.
Then, I use multi-threading to have a try:
import omni
import random
import threading
return stage
stage_num = 10
threads = []
t = threading.Thread(target=create_stage_with_sphere, args=(i,))
t.start()
threads.append(t)
for t in threads:
t.join()
for i in stage_num:
When I execute the version with multi threads, Omniverse would be stuck, and I cannot get any responses like log info or error messages.
If multi-threading is doable in Omniverse, could you help me to solve this problem?
Thank you so much!
