Hello,We use SDkManager to flash TX2 with jetpack 4.6, but the following problems appear, may I ask how to fix, thanks
23:18:07 INFO: File System and OS - target_image: verifying checksum of /home/xjd/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.6.1_aarch64.tbz2
23:18:09 INFO: File System and OS - target_image: Found file /home/xjd/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.6.1_aarch64.tbz2 with correct checksum, skip downloading.
23:18:16 INFO: File System and OS - target_image: verifying checksum of /home/xjd/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.6.1_aarch64.tbz2
23:18:19 INFO: File System and OS - target_image: Found file /home/xjd/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R32.6.1_aarch64.tbz2 with correct checksum, skip downloading.
23:19:20 DEBUG: File System and OS - target_image: using adapter to install NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP@JETSON_TX2_TARGETS to /home/xjd/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/rootfs/
23:19:20 INFO: File System and OS - target_image: NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP include 1 package
23:19:20 INFO: File System and OS - target_image: exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP.sh
23:19:20 INFO: File System and OS - target_image: *begin sudo apt-get install -y qemu-user-static , 5
23:19:20 INFO: File System and OS - target_image: Reading package lists…
23:19:20 INFO: File System and OS - target_image: Building dependency tree…
23:19:20 INFO: File System and OS - target_image: Reading state information…
23:19:20 INFO: File System and OS - target_image: qemu-user-static is already the newest version (1:2.11+dfsg-1ubuntu7).
23:19:20 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
23:19:20 INFO: File System and OS - target_image: *begin sudo apt-get install -y python , 5
23:19:21 INFO: File System and OS - target_image: Reading package lists…
23:19:21 INFO: File System and OS - target_image: Building dependency tree…
23:19:21 INFO: File System and OS - target_image: Reading state information…
23:19:21 INFO: File System and OS - target_image: The following packages have unmet dependencies:
23:19:21 INFO: File System and OS - target_image: Depends: python2.7 (>= 2.7.15~rc1-1~) but it is not going to be installed
23:19:21 ERROR: File System and OS - target_image: E: Unable to correct problems, you have held broken packages.
23:19:21 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP Install took 1s ]
23:19:21 ERROR: File System and OS - target_image: command terminated with error
