Using CUDA profiler in text mode
I am trying to acces cuda profiler in text mode. Here is what I am doing.
#nvcc myfile.cu -o myfile
#export CUDA_PROFILE=1 CUDA_PROFILE_CSV=1 CUDA_PROFILE_CONFIG=myconf
#./myfile
Once I do this I am getting a file: cuda_profile_0.log that says:
NV error: Failed to open profile config file: myconfig
NV error: Profiler Initialization failed
Can anybody tell me how do I solve this problem?
Thanks in advance
Define the environment variable CUDA_PROFILE_LOG as well. e.g.
export CUDA_PROFILE_LOG=$HOME/(name of your output file)
Thank you very much for the help. Now I by the grace of God I am getting the file “myconf”. But the problem is when I open the file myconf I get the following output:
NV_Error: Profiler config file myconf is of zero length.
NV_Error: Profiler initialization failed
External Media
Also do you think the sequence of operation that I am following is correct (kindly see my first post in this thread)…
BTW can we use CUDA profiler in LAN eg. using putty ?
