Hello I’m building a UI for my extension and i wanted to use gradients as colors for backgrounds and borders. I already know how to assign the different button states, colors, borders etc to the buttons.
I stareted here: Gradient Style Window — Omniverse Workflows
I fixed the TypeError with the compression format being wrong.
from omni.gpu_foundation_factory import TextureFormat
format = omni.gpu_foundation_factory.TextureFormat.RGBA8_SRGB # Example format, adjust as needed
so now i can see all gradients in the tutorial. I am however still trying to understand how the colors can be used as border colors or background colors for buttons, fields etc.
I understand that this is the main function for constructing the gradients and i am able to get it to show a gradient in a HStack() in my UI:
build_gradient_image(colors, height, style_name):
I am not able to assign it to a variable and use it as a color though. Here i am stuck and any help would be appricaiated.
I think this has something to do with getting the gradient as a color:
# for Gradient Image
"ImageWithProvider::gradient_slider":{"border_radius": 128, "corner_flag": ui.CornerFlag.ALL},
"ImageWithProvider::button_background_gradient": {"border_radius": 0, "corner_flag": ui.CornerFlag.ALL},
Also this in the tutorial:
With this, the user will be able to generate gradient image easily which also allows flexibly set the height and style. Here are a couple of examples used in the example:
colors = cls_color_gradient = [cl("#fa0405"), cl("#95668C"), cl("#4b53B4"), cl("#33C287"), cl("#9fE521"), cl("#ff0200")]
byte_provider = build_gradient_image(colors, 8, "gradient_slider")
cls_button_gradient = [cl("#232323"), cl("#656565")]
button_background_gradient = build_gradient_image(cls_button_gradient, 22, "button_background_gradient")
I would like to assign it to something like cl_myColorGradient and then use it in the style guide.
← this is a real button.
