I’m trying to use uridecodebin with nvDecoder with no success
example:
gst-launch-1.0 uridecodebin uri=“file://4K_standing.mp4” ! h264parse ! nvdec_h264 ! nvvidconv ! “video/x-raw(memory:NVMM),format=(string)RGBA” ! dsexample processing-width=1920 processing-height=1080 ! nvosd ! nveglglessink
please advise
Hi robertpfjq08,
Are you able to run the pipeline in user guide?
gst-launch-1.0 filesrc location=<path-to-stream> ! decodebin ! nvvidconv ! dsexample full-frame=1 <other-properties> ! nvosd ! nveglglessink
yes, this line is working
Hi robertpfjq08,
uridecodebin will search for decoder, so you should run
gst-launch-1.0 uridecodebin uri="file://4K_standing.mp4" ! nvvidconv ! dsexample full-frame=1 <other-properties> ! nvosd ! nveglglessink
Please give it a try.
Hi DaneLLL,
thank you for the answer, this works fine.
uridecodebin will search for a decoder, i don’t which one he will pick.
Can i specify him from code/command line which one to pick?
You should be able to run a pipeline:
gst-launch-1.0 filesrc location=<path-to-stream> ! qtdemux ! h264parse ! _SPECIFIC_DECODER_ ! nvvidconv ! dsexample full-frame=1 <other-properties> ! nvosd ! nveglglessink
