• Hardware Platform (Jetson / GPU) GPU RTX3080
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 3.5.2
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 535.129.03
I have this error at deepstream-app only today (used to be working fine).
/usr/bin/ld: cannot find -lcuda
So config file and makefile are attached.
AH_application_primary.txt (3.5 KB)
AH_application_main.txt (8.3 KB)
CUDA_VER?=12.1
ifeq ($(CUDA_VER),)
$(error "CUDA_VER is not set")
endif
APP:= deepstream-app
TARGET_DEVICE = $(shell gcc -dumpmachine | cut -f1 -d -)
NVDS_VERSION:=6.3
LIB_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/
APP_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/bin/
ifeq ($(TARGET_DEVICE),aarch64)
CFLAGS:= -DPLATFORM_TEGRA
endif
SRCS:= $(wildcard *.c) $(wildcard *.cpp)
SRCS+= $(wildcard ../../apps-common/src/*.c)
SRCS+= $(wildcard ../../apps-common/src/deepstream-yaml/*.cpp)
INCS:= $(wildcard *.h)
PKGS:= gstreamer-1.0 gstreamer-video-1.0 x11 json-glib-1.0
OBJS:= $(SRCS:.c=.o)
OBJS:= $(OBJS:.cpp=.o)
CFLAGS+= -I./ -I../../apps-common/includes \
-I../../../includes -DDS_VERSION_MINOR=1 -DDS_VERSION_MAJOR=5 \
-I /usr/local/cuda-$(CUDA_VER)/include
LIBS:= -L/usr/local/cuda-$(CUDA_VER)/lib64/ -lcudart
LIBS+= -L$(LIB_INSTALL_DIR) -lnvdsgst_meta -lnvds_meta -lnvdsgst_helper -lnvdsgst_customhelper \
-lnvdsgst_smartrecord -lnvds_utils -lnvds_msgbroker -lm -lyaml-cpp \
-lcuda -lgstrtspserver-1.0 -ldl -Wl,-rpath,$(LIB_INSTALL_DIR)
CFLAGS+= $(shell pkg-config --cflags $(PKGS))
LIBS+= $(shell pkg-config --libs $(PKGS))
all: $(APP)
%.o: %.c $(INCS) Makefile
$(CC) -c -o $@ $(CFLAGS) $<
%.o: %.cpp $(INCS) Makefile
$(CXX) -c -o $@ $(CFLAGS) $<
$(APP): $(OBJS) Makefile
$(CXX) -o $(APP) $(OBJS) $(LIBS)
install: $(APP)
cp -rv $(APP) $(APP_INSTALL_DIR)
clean:
rm -rf $(OBJS) $(APP)
But in gst-dsexample folder, it worked fine.
I can do nvidia-smi.
All cuda are working fine.
Why can’t i build deepstream-app. It used to be working well before holidays break.
