Deep Stream App running error
I installed Deep Stream 6.3 in my NVIDIA Jetson Xavier NX development Kit. While running a deep stream app I am getting following error,
Please suggest what could be the reason for this error.
Hi there @dpalai,
Are you certain that you have the CUDA toolkit installed? You could check for example like this:
ls -ll /usr/local/cuda/lib64/libcudla*
lrwxrwxrwx 1 root root     13 Sep 14  2022 /usr/local/cuda/lib64/libcudla.so -> libcudla.so.1
lrwxrwxrwx 1 root root     17 Sep 14  2022 /usr/local/cuda/lib64/libcudla.so.1 -> libcudla.so.1.0.0
-rw-r--r-- 1 root root 179792 Sep 14  2022 /usr/local/cuda/lib64/libcudla.so.1.0.0
If the file exists, check that the app can correctly find it. Since I am not a DeepStream expert I don’t know exactly how that is set up, so I refer you to their forum category.
If you want run DS-6.3 on Jetson, JetPack must be installed first.
You can refer this documetaion.
I recommend you use sdkmanager to flash Jetpack
My Jetson Xavier Nx already has JetPack. I installed the latest CUDA Toolkit. But I am not getting libcudla.so.1 in /usr/local/cuda/lib64/
I installed latest CUDA Toolkit. But not getting libcudla.so.1 in /usr/local/cuda/lib64/
