I am developing a camera driver on the Jetson platform for a custom camera. I was using Camera Driver Development 2.0 as a guide.
I am not using the ISP since I am using v4l2-ctl to capture test frames. My driver is working correctly on Jetson Nano. For porting to Jetson Xavier NX I created another device tree.
For Nano I was using device tree from imx185 as an example, while for Xavier NX I was using the examples for imx219 (which is originally for two cameras right away, maybe there is the problem).
The sensor format is 10bit, so capturing with v4l2-ctl I am opening the images in python numpy in uint16. Showing the pixels in binary looks like this:
Looking at those values you can see, that only the 7bit in the middle change surrounded by 000 zeroes on both ends. The last 3 bits are always replicate of the first 3 from the middle 7 bit.
0001100000000110
0001101101000110
0001100101000110
0001101110000110
0001100000000110
0001110001000111
0001011110000101
0001101100000110
0001100011000110
0001110011000111
0001100011000110
How come I see such behavior with Jetson NX, but with Jetson Nano it is totally fine? That can only come from different device tree, since my driver source file is the same, right?
Maybe you can have a look at my device trees and tell me what I am doing wrong?
Device Tree of XAVIER (not working):
* Copyright (c) 2018-2020, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see http://www.gnu.org/licenses/.
#include <dt-bindings/media/camera.h>
host1x {
vi@15c10000 {
num-channels = <2>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
rbpcv2_OH02A10_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_OH02A10_csi_out0>;
vi_port1: port@1 {
reg = <1>;
rbpcv2_OH02A10_vi_in1: endpoint {
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_OH02A10_csi_out1>;
nvcsi@15a00000 {
num-channels = <2>;
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
rbpcv2_OH02A10_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_OH02A10_out0>;
csi_chan0_port1: port@1 {
reg = <1>;
rbpcv2_OH02A10_csi_out0: endpoint@1 {
remote-endpoint = <&rbpcv2_OH02A10_vi_in0>;
csi_chan1: channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
csi_chan1_port0: port@0 {
reg = <0>;
rbpcv2_OH02A10_csi_in1: endpoint@2 {
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_OH02A10_out1>;
csi_chan1_port1: port@1 {
reg = <1>;
rbpcv2_OH02A10_csi_out1: endpoint@3 {
remote-endpoint = <&rbpcv2_OH02A10_vi_in1>;
cam_i2cmux {
i2c_0:i2c@0 {
OH02A10_cam0: rbpcv2_OH02A10_a@36 {
compatible = "nvidia,OH02A10";
/* I2C device address */
reg = <0x36>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.680";
physical_h = "2.760";
sensor_model = "OH02A10";
use_sensor_mode_id = "true";
* ==== Modes ====
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* == Signal properties ==
* phy_mode = "";
* PHY mode used by the MIPI lanes for this device
* tegra_sinterface = "";
* CSI Serial interface connected to tegra
* Incase of virtual HW devices, use virtual
* For SW emulated devices, use host
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* == Image format Properties ==
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* pixel_t = "";
* The sensor readout pixel pattern
* line_length = "";
* Pixel line length (width) for sensor mode.
* == Source Control Settings ==
* Gain factor used to convert fixed point integer to float
* Gain range [min_gain/gain_factor, max_gain/gain_factor]
* Gain step [step_gain/gain_factor is the smallest step that can be configured]
* Default gain [Default gain to be initialized for the control.
* use min_gain_val as default for optimal results]
* Framerate factor used to convert fixed point integer to float
* Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor]
* Framerate step [step_framerate/framerate_factor is the smallest step that can befor configured]
* Default Framerate [Default framerate to be initialized for the control.
* use max_framerate to get required performance]
* Exposure factor used to convert fixed point integer to float
* For convenience use 1 sec = 1000000us as conversion factor
* Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can befor configured]
* Default Exposure Time [Default exposure to be initialized for the control.
* Set default exposure based on the default_framerate for optimal exposure settings]
* gain_factor = ""; (integer factor used for floating to fixed point conversion)
* min_gain_val = ""; (ceil to integer)
* max_gain_val = ""; (ceil to integer)
* step_gain_val = ""; (ceil to integer)
* default_gain = ""; (ceil to integer)
* Gain limits for mode
* exposure_factor = ""; (integer factor used for floating to fixed point conversion)
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* step_exp_time = ""; (ceil to integer)
* default_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (sec)
* framerate_factor = ""; (integer factor used for floating to fixed point conversion)
* min_framerate = ""; (ceil to integer)
* max_framerate = ""; (ceil to integer)
* step_framerate = ""; (ceil to integer)
* default_framerate = ""; (ceil to integer)
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 {/*mode OH02A10_MODE_1920X1080_CROP_30FPS*/
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "10";
csi_pixel_bit_depth = "10";
mode_type = "bayer";
pixel_phase = "rggb";
active_w = "1920";
active_h = "1080";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "6";
pix_clk_hz = "144000000";
gain_factor = "10";
min_gain_val = "0"; /* 0dB */
max_gain_val = "480"; /* 48dB */
step_gain_val = "3"; /* 0.3 */
default_gain = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "1500000"; /* 1.5 */
max_framerate = "60000000"; /* 30 */
step_framerate = "1";
default_framerate= "60000000";
exposure_factor = "6000000";
min_exp_time = "30"; /* us */
max_exp_time = "660000"; /* us */
step_exp_time = "1";
default_exp_time = "33334";/* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_OH02A10_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_OH02A10_csi_in0>;
i2c_1: i2c@1 {
OH02A10_cam1: rbpcv2_OH02A10_c@36 {
reg = <0x36>;
devnode = "video1";
* ==== Modes ====
* phy_mode = "";
* pix_clk_hz = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
* Framerate step [step_framerate/framerate_factor is the smallest step that can be configured]
* Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured]
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
gain_factor = "10";
default_gain = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv2_OH02A10_out1: endpoint {
status = "okay";
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_OH02A10_csi_in1>;
lens_OH02A10@RBPCV2 {
min_focus_distance = "0.0";
hyper_focal = "0.0";
focal_length = "3.04";
f_number = "2.0";
aperture = "0.0";
tcp: tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <240000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. "rear" or "front".
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vendor.
modules {
cam_module0: module0 {
badge = "jakku_front_RBP194";
position = "front";
orientation = "1";
cam_module0_drivernode0: drivernode0 {
pcl_id = "v4l2_sensor";
devname = "OH02A10 9-0036";
proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@0/rbpcv2_OH02A10_a@36";
cam_module0_drivernode1: drivernode1 {
pcl_id = "v4l2_lens";
proc-device-tree = "/proc/device-tree/lens_OH02A10@RBPCV2/";
cam_module1: module1 {
badge = "jakku_rear_RBP194";
position = "rear";
orientation = "1";
cam_module1_drivernode0: drivernode0 {
devname = "OH02A10 10-0036";
proc-device-tree = "/proc/device-tree/cam_i2cmux/i2c@1/rbpcv2_OH02A10_c@36";
cam_module1_drivernode1: drivernode1 {
Device Tree for Jetson Nano (working):
* Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
* more details.
#include <dt-bindings/platform/t210/t210.h>
#define CAM1_PWDN TEGRA_GPIO(S, 7)
host1x {
vi_base: vi {
num-channels = <1>;
ports {
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
liOH02A10_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&liOH02A10_csi_out0>;
csi_base: nvcsi {
num-channels = <1>;
#size-cells = <0>;
reg = <0>;
ports {
#size-cells = <0>;
reg = <0>;
liOH02A10_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&liOH02A10_OH02A10_out0>;
reg = <1>;
liOH02A10_csi_out0: endpoint@1 {
remote-endpoint = <&liOH02A10_vi_in0>;
i2c@546c0000 {
OH02A10_a@36 {
reg = <0x36>;
reset-gpios = <&gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
physical_w = "15.0";
physical_h = "12.5";
sensor_model ="OH02A10";
/* Define any required hw resources needed by driver */
/* ie. clocks, io pins, power sources */
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
post_crop_frame_drop = "0";
/* Convert Gain to unit of dB (decibel) befor passing to kernel driver */
use_decibel_gain = "false";
/* if true, delay gain setting by one frame to be in sync with exposure */
delayed_gain = "true";
/* enable CID_SENSOR_MODE_ID for sensor modes selection */
* ==== Modes ====
* phy_mode = "";
* pix_clk_hz = "";
* active_w = "";
* active_h = "";
* pixel_t = "";
* line_length = "";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
gain_factor = "10";
default_gain = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
liOH02A10_OH02A10_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&liOH02A10_csi_in0>;
gpio@6000d000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = < CAM1_PWDN 0 >;
label = "cam1-pwdn";
num_csi_lanes = <2>;
* in the module's specsheet from the vender.
modules {
badge = "OH02A10_bottom_liOH02A10";
position = "bottom";
orientation = "0";
/* Declare PCL support driver (classically known as guid) */
/* Driver v4l2 device name */
devname = "OH02A10 30-0036";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/tca9546@70/i2c@0/OH02A10_a@36";
Thank you very much for any help,
jb
