Vgem_dri.so file is missing libEGL warning
libEGL warning: MESA-LOADER: failed to open vgem: /usr/lib/dri/vgem_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
Hello I get the error above when I want to run a neural network and it seems the /usr/lib/dri/ folder is missing completely and in the /usr/lib/x86_64-linux-gnu/dri folder are a lot of .so files but a vgem_dri.so file is missing. Does this mean something with my WSL2 system is wrong? I am using a WSL2 with Cuda 11.7. My nvidia-smi and nvcc --version output is below:
kiropro@DESKTOP-JC8EGB7:~$ nvidia-smi
Tue Feb 28 15:50:13 2023
| NVIDIA-SMI 525.89.02    Driver Version: 528.49       CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  On   | 00000000:01:00.0  On |                  Off |
| 64%   56C    P2   268W / 450W |   4660MiB / 24564MiB |     97%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A        27      G   /Xwayland                       N/A      |
kiropro@DESKTOP-JC8EGB7:~$ nvcc --version
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Wed_Jun__8_16:49:14_PDT_2022
Cuda compilation tools, release 11.7, V11.7.99
Build cuda_11.7.r11.7/compiler.31442593_0
Any solution for this? I’m facing the same problem
Unfortunately not, I will try to use a Linux system in the next weeks, if it works there I will tell you. If you find a solution on another way I would appreciate it if you would tell it to me
