I am in the process of getting vino-server running on my Orin Nano that I previously was running on my Xavier NX without issue. On my Xavier NX, I was able to follow these instructions and everything works well.
On the Orin Nano, I followed the same instructions, but it seems that vino-server is autostarting, but then autostopping. I can start it up again manually and everything works, but I am wondering why it is stopping right after it autostarts.
When I run systemctl --user status vino-server.service
it shows this:
Loaded: loaded (/usr/lib/systemd/user/vino-server.service; static; vendor preset: enabled)
Active: inactive (dead) since Fri 2023-08-11 09:49:30 MDT; 41min ago
Process: 3438 ExecStart=/usr/lib/vino/vino-server (code=killed, signal=TERM)
Main PID: 3438 (code=killed, signal=TERM)
Aug 11 09:49:03 ubuntu vino-server[3438]: 11/08/2023 09:49:03 AM Advertising security type: 'TLS' (18)
Aug 11 09:49:03 ubuntu vino-server[3438]: 11/08/2023 09:49:03 AM Advertising authentication type: 'VNC Authentication' (2)
Aug 11 09:49:03 ubuntu vino-server[3438]: 11/08/2023 09:49:03 AM Clearing securityTypes
Aug 11 09:49:03 ubuntu vino-server[3438]: 11/08/2023 09:49:03 AM Clearing authTypes
Aug 11 09:49:03 ubuntu vino-server[3438]: 11/08/2023 09:49:03 AM Advertising security type: 'VNC Authentication' (2)
Aug 11 09:49:30 ubuntu systemd[1375]: Stopping Vino VNC server...
Aug 11 09:49:30 ubuntu systemd[1375]: vino-server.service: Succeeded.
Aug 11 09:49:30 ubuntu systemd[1375]: Stopped Vino VNC server.
I’m running Jetpack 5.1.1 (Ubuntu 20.04)
As far as I can recall, I have done everything exactly the same as when I set this up on my Xavier NX (Jetpack 4.6.2 - Ubuntu 18.04).
The vino-server.service file looks like this:
[Unit]
Description=Vino VNC server
[Service]
Type=dbus
BusName=org.gnome.Vino
Restart=on-abnormal
Any idea what’s going on here, how to fix it, or how I can get to the bottom of what is happening?
Edit (a bit more info): It seems to run fine if I just manually do systemctl --user restart vino-server.service
So it’s only when my system is first starting up that its a problem. I tried adding some delay with ExecStartPre=/bin/sleep 10
(and 20, 30, 60), but that seemed to cause another error:
-- Logs begin at Thu 2022-09-08 03:58:15 MDT. --
Aug 11 11:48:47 ubuntu systemd[1380]: Starting Vino VNC server...
Aug 11 11:48:50 ubuntu systemd[1380]: vino-server.service: Control process exited, code=killed, status=15/TERM
Aug 11 11:48:50 ubuntu systemd[1380]: vino-server.service: Failed with result 'signal'.
Aug 11 11:48:50 ubuntu systemd[1380]: Stopped Vino VNC server.
which suggests to me it isn’t even able to do the ExecStartPre=/bin/sleep 10
, but I’m no expert.
