Visual Profiler
I am using an orin nano with the latest cuda (10.8) and I am trying to use nvidia visual profiler on Windows 11.
When I attempt to remote login, the nano auth log shows:
Unable to negotiate with 192.168.x.x port 52216: no matching host key type found. Their offer: ssh-rsa,ssh-dss [preauth]
I am not sure how to fix this. I can ssh into the orin nano from the Windows 11 machine so it appears that the keys are fine.
Any suggestions on how to fix this?
Malcolm
Hi, @malcolm12
Are you talking about CUDA 11.8 ?
Do you have CUDA 11.8 installed on both Windows and nano, and try to remote profile from Windows ?
Yes. Cuda 11.8. I have it installed on both Windows and the orin nano. I am trying to connect the Windows Visual Profiler to the orin nano to profile applications. I can see that the orin nano sees the connection attempt but won’t accept the ssh connection. The is from the orin nano auth log
I can ssh from Windows to the orin nano without a problem.
I want to know how to connect Visual Profiler to the orin nano to overcome the above error.
Malcolm
Any thoughts for help on this issue. It’s important.
Hi, @malcolm12
From the log, this still seems ssh connection issue not Visual Profiler.
I do found similar topic https://askubuntu.com/questions/836048/ssh-returns-no-matching-host-key-type-found-their-offer-ssh-dss
Also note Visual Profiler will be dropped in our future release soon. For trace/profile usage, please switch to new tools Nsight Compute | NVIDIA Developer | NVIDIA Developer and Nsight Systems | NVIDIA Developer
