I use the vtk 5.8 libraries as part of a 3d rendering application. It has worked without issue until I tried to use it with the GTX Titan card. One of the renderers, “vtkOpenGLGPUVolumeRayCastMapper” does not work with the Titan card. I get a black screen where the volume should be rendered and a message “Loading the streamed block FAILED!!!”. This renderer has worked with all 600 series and below Nvidia GPUs. Does anyone have any information about changes to OpenGL or its drivers that may have caused this renderer to stop working? I would like to continue to use vtk 5.8, as the application is very mature and would require a huge effort to port to the newer vtk version.
Related topics
| Example program volumeRender complains about OpenGL | 1 | 1241 | July 13, 2009 | |
| 8800GTS 512 + ATI X850XT works, but not perfect | 2 | 2370 | August 31, 2009 | |
| Strange results for Whitted tracer for GTX580 vs Titan | 5 | 1035 | June 14, 2022 | |
| There is no device (GeForce 8800) | 3 | 5259 | April 28, 2007 | |
| GF driver for cuda in vista x64 but w/o opengl | 13 | 6900 | April 20, 2008 | |
| extension `GL_EXT_gpu_shader4' unsupported in fragment shader | 0 | 3097 | February 16, 2016 | |
| OptiX 5 + cuda 9 + titan V causing 'gl buff objects must be same size as optix buff objs' | 12 | 1439 | June 14, 2022 | |
| doubts about TCC-driver Tesla + GTX480 --> will OpenGL run on GTX480? | 4 | 1690 | December 21, 2010 | |
| Geforce GTX Titan: no CUDA-capable device is detected (error 38) | 5 | 3631 | September 5, 2013 | |
| Problems running CUDA on non-primary display | 23 | 54670 | June 27, 2008 |
