Can not install driver. Installator fails “System check” stage. Does GTX 750 really supports Vulkan?
GTX 750 should be supported. Sorry that the driver didn’t install out-of-the-box.
Possible causes :
You uninstalled the previous driver and did not reboot before installing the new driver
Your installation was intercepted by Windows (or Windows Update) installing a driver at the same time, which can happen when Windows is setup to automatically install drivers
If you were not able to install the driver after a reboot, could you please collect the installer logs, as detailed here…
http://nvidia.custhelp.com/app/answers/detail/a_id/3581/~/driver-installation-failed
http://nvidia.custhelp.com/app/answers/detail/a_id/3171
and then submit via:
https://developer.nvidia.com/content/nvidia-dev-support-submission-form
Thanks,
Mathias
