Vulkan driver upgrade not working
Ubuntu 16.04
64 bit
GeForce GT 710 (has Vulkan support!)
Hey,
I tried to install the vulkan driver upgrade from this page: Vulkan Driver Support | NVIDIA Developer
I chose the 64 bit version, logged out, closed x-session, made it executable, run it and recieved the following error log…
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Wed Aug 24 12:49:41 2016
installer version: 367.27
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
nvidia-installer command line:
    ./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> Detected 8 CPUs online; setting concurrency level to 8.
-> License accepted.
-> Installing NVIDIA driver version 367.27.
-> Running distribution scripts
   executing: '/usr/lib/nvidia/pre-install'...
-> done.
-> The distribution-provided pre-install script failed!  Are you sure you want to continue? (Answer: Continue installation)
ERROR: The Nouveau kernel driver is currently in use by your system.  This driver is incompatible with the NVIDIA driver, and must be disabled before proceeding.  Please consult the NVIDIA driver README and your Linux distribution's documentation for details on how to correctly disable the Nouveau kernel driver.
WARNING: One or more modprobe configuration files to disable Nouveau are already present at: /etc/modprobe.d/nvidia-installer-disable-nouveau.conf.  Please be sure you have rebooted your system since these files were written.  If you have rebooted, then Nouveau may be enabled for other reasons, such as being included in the system initial ramdisk or in your X configuration file.  Please consult the NVIDIA driver README and your Linux distribution's documentation for details on how to correctly disable the Nouveau kernel driver.
ERROR: Installation has failed.  Please see the file '/var/log/nvidia-installer.log' for details.  You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
I’m following the tutorial on http://www.vulkan-tutorial.com . example doesn’t work, 'cause the vulkan driver doesn’t work. so why is that? I followed the simple steps… it makes no sense…
Thanks for any help in advance
Lines 20 and 21 in the error log you pasted explain why the driver could not be installed. It appears that the nouveau driver is in use. The procedure for disabling it is specific to your distribution.
Alternatively, since you are on Ubuntu, I would recommend installing the latest drivers available on the graphics-driver PPA:
[url]http://www.webupd8.org/2016/06/how-to-install-latest-nvidia-drivers-in.html[/url]
