VulkanSDK (latest) installation on Jetson Orin Nano
I need to install the latest version of the VulkanSDK 1.4 on the Jetson Orin Nano. Is there is way to install it?
GPU Configuration:
Package: nvidia-jetpack
Version: 6.2.1+b38
Priority: standard
Section: metapackages
Source: nvidia-jetpack (6.2.1)
Maintainer: NVIDIA Corporation
Installed-Size: 199 kB
Depends: nvidia-jetpack-runtime (= 6.2.1+b38), nvidia-jetpack-dev (= 6.2.1+b38)
Homepage: Jetson - Embedded AI Computing Platform | NVIDIA Developer
Download-Size: 29.3 kB
APT-Manual-Installed: yes
APT-Sources: https://repo.download.nvidia.com/jetson/common r36.4/main arm64 Packages
Description: NVIDIA Jetpack Meta Package
Kernel: 5.15.148-tegra
L4T 36.4.4
We would suggest use Vulkan 1.3 as recommended in
Jetson Linux Release 36.4.4 | NVIDIA Developer
There may be potential issues if you use other version.
The application is already using Vulkan 1.4 and does not have for Vulkan 1.3 of it as far as I know. Is there a way to install Jetpack 7 on Jetson Orin Nano?
This is not supported. Jetpack 7 supports only AGX Thor.
