during our test drive, our W10 desktops with Update 1809 freeze when unlocking a locked VM. Not everytime, but very often.
Drivers used: NVIDIA-GRID-vSphere-6.5-410.92-410.91-412.16
Hardware: Tesla M60 - grid_m60-2b
Citrix_Virtual_Apps_and_Desktops_7_1808_2
I. Can anyone confirm this combination to run stable and what has to be done for that?
II. I see there is still no official support running W10 1809 and nVidia Grid at this time - when will it come?
Seems to be an issue with display timeout and Citrix. Start disabling display timeout for the VMs and open a support case with Citrix to further investigate.
Probably caused by : dxgkrnl.sys ( dxgkrnl!memset+a4 )
km:av_invalid_dxgkrnl!memset
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffae8bfa693000, memory referenced.
Arg2: 0000000000000002, value 0 = read operation, 1 = write operation.
Arg3: fffff80260e12324, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Any news about this issue? I am experiencing the same problem and can reproduce it every time.
I changed the screensaver timeout to 5 minutes. After unlocking the VM crashes immediately.
The crashdump also says: "AV_INVALID_dxgkrnl!memset"
Details about our environment:
Citrix VDA 1903 (connected to Citrix Cloud)
Windows 10 1809
VMware vSphere 6.7 Update 2
NVIDIA GRID vGPU grid_m10-1b
NVIDIA Driver version 425.31
"C:\Program Files\Citrix\ICAService\NvFBCEnable.exe" -checkstatus gives me the result that FBC is disabled. After enabling FBC (-enable paramater) I cannot reproduce the issue anymore. I will do some further testing with this setting.
[i]Install and upgrade NVIDIA drivers
The NVIDIA GRID API provides direct access to the frame buffer of the GPU, providing the fastest possible frame rate for a smooth and interactive user experience. If you install NVIDIA drivers before you install a VDA with HDX 3D Pro, NVIDIA GRID is enabled by default.
To enable NVIDIA GRID on a VM, disable Microsoft Basic Display Adapter from the Device Manager. Run the following command and then restart the VDA: NVFBCEnable.exe -enable -noreset
If you install NVIDIA drivers after you install a VDA with HDX 3D Pro, NVIDIA GRID is disabled. Enable NVIDIA GRID by using the NVFBCEnable tool provided by NVIDIA.
To disable NVIDIA GRID, run the following command and then restart the VDA: NVFBCEnable.exe -disable -noreset[/i]
I don’t think this is relevant here. I cannot reproduce the issue no matter if I run NVFBC enabled or disabled. This is most likely a timing issue with ICA idle.
In addition Citrix changed the capture mode from NVFBC to DDAPI with 1809 and CVAD1903…
I can replicate this consistently with 1809 in my Lab (ESXi 6.7 U2 > Clean build of W10 1809 with all Windows Updates > CVAD 1906 > vGPU 8.0 with QvDWS). The moment I lock the VM, it crashes.
I’ve also tested the exact same configuration with W10 1903, and although vGPU 8.0 with 1903 is currently unsupported, this crashing issue does not occur.
You have a couple of choices … Either stay on 1803 and be supported without the issue, or if you really need to upgrade, move to 1903 currently unsupported but (from my tests) working and in preparation for the next vGPU release. I’ve tried 3D Apps on 1903 and had no issues with stability or performance and due to NVIDIA’s quick release cycle, it shouldn’t be too long before a vGPU upgrade comes along that will support 1903 …
Once again:
This is not a vGPU issue so independent from vGPU version. It can only be reproduced with Citrix stack involved and Citrix is already further investigating. @Ben: Thanks for testing with 1903 as we now have at least a workaround until Citrix provides a fix for 1809.
I am running W10 1809 and Driver 8.1.940. I still have freeze issues with multi monitors.
Going to W10 1903 is not option right now. Does anybody if there will be a updated driver?
