Hi, I am testing my Jetson AGX Thor development kit I just bought. I have installed the Jetson ISO image by using an installation USB and also installed Jetpack 7.When I make the Docker Setup Test by running a PyTorch container as the
following command:
"docker run --rm -it \
-v "$PWD":/workspace \
-w /workspace \
nvcr.io/nvidia/pytorch:25.08-py3"
The terminal displayed errors as:
"WARNING: The NVIDIA Driver was not detected. GPU functionality will not be available.
Use the NVIDIA Container Toolkit to start this container with GPU support; see
https://docs.nvidia.com/datacenter/cloud-native/ ."
So, my questions are:
1. Is the GPU driver not installed when the Jetson ISO image was installed?
2. Do I need to reinstall the GPU driver? How to install the driver and what is the compatible version of the driver? Thanks. BEN
You could to âsudo apt search nvidia-containerâ to make sure it is installed and if not
sudo apt install nvidia-container
and make sure this file /etc/docker/daemon.json has these contents.
"runtimes": {
"nvidia": {
"args": [],
"path": "nvidia-container-runtime"
"default-runtime": "nvidia"
and or add this to your docker run --runtime nvidia
Hi, whitesscott,
Thank you for your reply. Now the GPU driver is detected. Then I continue to perform CUDA setup according to the user guide.
I are trying the Example 2: Build cuda-samples using NGC CUDA container, and input the following command:
âcd ~
mkdir -p $HOME/cuda-work && cd $HOME/cuda-work
docker run --rm -it
-v â$PWDâ:/workspace
-w /workspace
nvcr.io/nvidia/cuda:13.0.0-devel-ubuntu24.04â
After the CUDA container is running, then I input:
âapt update && apt install -y --no-install-recommends git make cmake
git clone --depth=1 --branch v13.0 GitHub - NVIDIA/cuda-samples: Samples for CUDA Developers which demonstrates features in CUDA Toolkit
cd cuda-samples/Samples/1_Utilities/deviceQuery
cmake . -DGPU_TARGETS=all -DCMAKE_BUILD_TYPE=Release
make -j$(nproc)
./deviceQueryâ
But the result displays failure:
"root@eea659b120f8:/workspace/cuda-samples/Samples/1_Utilities/deviceQuery# ./deviceQuery
./deviceQuery StartingâŠ
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 803
â system has unsupported display driver / cuda driver combination
Result = FAIL"
So, can you tell what wrong with this? Why âsystem has unsupported display driver / cuda driver combinationâ?
I tried the sudo apt install nvidia-cuda-samples and the build failed; those are not for Thor but Orin I think. I then decided to try v13.0 which was just recently released and has been modified to work with Thor / CUDA 13.
Hereâs the steps I took to install them natively on Thor. You could do the same presumably in a container.
sudo apt install cmake openmpi-bin libopenmpi-dev
wget https://github.com/NVIDIA/cuda-samples/archive/refs/tags/v13.0.tar.gz
tar xfz v13.0.tar.gz
rm v13.0.tar.gz
cd cuda-samples-13.0
mkdir build && cd build
cmake ..
make SMS="110" -j12
# There are many "warning" message while compiling but they do not effect the built executables.
# The sms=110 tells compiler to optimize the build for Thor. -j12 is # of processors to use.
# Then I moved the cuda-samples-13.0/build/Samples to home.
mv ./Samples ~/
The executables are in the various sub directories of Samples and can be run from home or from in the subdir.
~/Samples/1_Utilities/deviceQuery/deviceQuery
/home/scott/Samples/1_Utilities/deviceQuery/deviceQuery Starting...
Detected 1 CUDA Capable device(s)
Device 0: "NVIDIA Thor"
CUDA Driver Version / Runtime Version 13.0 / 13.0
CUDA Capability Major/Minor version number: 11.0
Total amount of global memory: 125772 MBytes (131881758720 bytes)
(020) Multiprocessors, (128) CUDA Cores/MP: 2560 CUDA Cores
GPU Max Clock rate: 1049 MHz (1.05 GHz)
Memory Clock rate: 0 Mhz
Memory Bus Width: 0-bit
L2 Cache Size: 33554432 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total shared memory per multiprocessor: 233472 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 13.0, CUDA Runtime Version = 13.0, NumDevs = 1
Result = PASS
Hi, whitesscott,
I just tried as your suggestion in the CUDA container, the problem is still the same:
â./deviceQuery StartingâŠ
Result = FAILâ
So, I do not think the problem is related to the release. It is already V13.0.
Can you try this in the nvcr.io/nvidia/cuda:13.0.0-devel-ubuntu24.04 container on the Jetson AGX thor development kit?
Hi, whitesscott,
I just install Jetpack 7, and I perform your suggested operations natively(not in container), it succeeds. So, I think the problem arise in cuda container, but not arise natively.
You can try this in cuda container, and you can repeat this problem and find a way to solve it. If you find the way to solve it in container, please share it with me.
Thanks. BEN
try this
cd ~/Samples #or where you have your natively compiled cuda-samples/Samples
docker run -it --net=host --runtime nvidia --privileged --ipc=host --ulimit memlock=-1 \
--ulimit stack=67108864 -v $(pwd):/workspace nvcr.io/nvidia/pytorch:25.08-py3 bash
Hi, whitesscott, I just tried as you said, and it succeeds. Thanks. BEN
