[me~]$ ethtool -g eth4
Ring parameters for eth4:
Pre-set maximums:
RX: 64
RX Mini: 0
RX Jumbo: 0
TX: 8192
Current hardware settings:
RX: 64
RX Mini: 0
1RX Jumbo: 0
TX: 8192
Pre-set maximums:
RX: 64
RX Mini: 0
RX Jumbo: 0
TX: 8192
RX: 64
RX Mini: 0
1RX Jumbo: 0
TX: 8192
Hello Anthony,
Thank you for posting your inquiry on the NVIDIA Networking Community.
Yes, you can change both TX and RX ring buffers to a max of 8192. Be aware that increasing the ring size buffer will allocated more memory. Make sure you have enough memory in your system to do this.
Command syntax:
# ethtool -G eth tx 8192 rx 8192
Thank you and regards,
~NVIDIA Networking Technical Support
@Martijn van Breugel Thank you for you response, yes I have already increased the buffer values but for clarification I wanted to know if I can change the pre-set RX 64 to higher value and then change the Current hardware settings from 64 to the new value if I can able to increase the pre-set max value of 64.
Please let me know if you need further details.
@Martijn van Breugel What I want to do is increase the buffer size for network interface card. With ethtool I have set the RX buffer size to 64 KB. But I want to increase to more than 64 KB. Is that possible, and what should I do?
