I run Isaac Sim docker container on a remote server with A100. Since A100 does not support NVENC, I am trying to stream via WebSocket using H264 encoding. However, when I try to connect to the server using the URL: http://<ip address>:8211/streaming/client, I get the error 404 Not Found. Can anyone help me? I don’t understand what the problem is or how to solve it
Additional Information:
- I use docker container and run it using command:
docker run --name isaac-sim --entrypoint bash -it --gpus device=0 -e "ACCEPT_EULA=Y" --rm --network=host -e "PRIVACY_CONSENT=Y" -v ~/docker/isaac-sim/cache/kit:/isaac-sim/kit/cache:rw -v ~/docker/isaac-sim/cache/ov:/root/.cache/ov:rw -v ~/docker/isaac-sim/cache/pip:/root/.cache/pip:rw -v ~/docker/isaac-sim/cache/glcache:/root/.cache/nvidia/GLCache:rw -v ~/docker/isaac-sim/cache/computecache:/root/.nv/ComputeCache:rw -v ~/docker/isaac-sim/logs:/root/.nvidia-omniverse/logs:rw -v ~/docker/isaac-sim/data:/root/.local/share/ov/data:rw -v ~/docker/isaac-sim/documents:/root/Documents:rw nvcr.io/nvidia/isaac-sim:2023.1.1
After this
netstat -lntushows that only 8211 is listen, but when I add flags -p 8211:8211 -p 8899:8899 and remove flag --network=hostnetstat -lntushows that ports 8211 and 8899 are listen -
In docker container i run ./runheadless.websocket.h264.sh
Ports 8899 and 8211 are opened
I connect to server via ssh + vpn
kit_20240212_204635.log (1.5 MB)
nvidia-smi:
Tue Feb 13 01:32:25 2024
| NVIDIA-SMI 535.154.05 Driver Version: 535.154.05 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA A100 80GB PCIe Off | 00000000:00:0D.0 Off | 0 |
| N/A 31C P0 60W / 300W | 35895MiB / 81920MiB | 0% Default |
| | | Disabled |
| 1 NVIDIA A100 80GB PCIe Off | 00000000:00:0E.0 Off | 0 |
| N/A 33C P0 74W / 300W | 27707MiB / 81920MiB | 100% Default |
| | | Disabled |
