We have two products based on the Jetson Xavier NX and Jetson Orin NX SOMs, respectively, and they are currently undergoing certification testing. The certification testing requires us to provide the CPU pin counts. Could you please let me know the CPU pin counts for the Xavier NX and Orin NX SOMs? Alternatively, is there any documentation or resource where I can find this information?
sgursal
3
If you are certifying a SOM module then not sure why CPU pin count is needed. SOM module uses 260 pin SODIMM connector. Does this answer your question?
Related topics
| Jetson Orin NX pins | 1 | 260 | September 5, 2024 | |
| Jetson NX Xavier SOM preferred connector | 1 | 876 | June 4, 2021 | |
| Orin NX's CPU computing power | 2 | 386 | April 15, 2024 | |
| Is there any way to test the Xavier NX SOM Module? | 1 | 662 | September 14, 2022 | |
| How to use pinmux spreadsheet for Orin SOM + Xavier Carrier board | 19 | 2356 | April 25, 2023 | |
| JETSON ORIN NX SOM - FCC OR UL CERTIFICATIONo | 2 | 263 | August 30, 2024 | |
| SDIO/ PCIe functionality difference | 2 | 935 | March 16, 2023 | |
| NVIDIA announces Jetson Xavier NX | 3 | 1683 | May 5, 2020 | |
| Request for GPIO Pin Mapping for Jetson Orin NX and AGX Modules | 6 | 98 | March 31, 2026 | |
| Marking on SOM'CPU | 1 | 900 | June 5, 2024 |
