What's the GCID in /etc/nv_tegra_release?
What’s the GCID in /etc/nv_tegra_release ?
It may be changed after re-flashing devkit, is it normal that GCID changed after re-flashing?
It should be fixed number along with release version. Take Jetpack 6.2(r36.4.3) as example:
$ cat /etc/nv_tegra_release
# R36 (release), REVISION: 4.3, GCID: 38968081, BOARD: generic, EABI: aarch64, D
ATE: Wed Jan  8 01:49:37 UTC 2025
We can see fix number for all platforms with r36.4.3. It is a bit strange you see it varying.
The GCID in above picture is from R36.3.0 (JetPack 6.0), not from r36.4.3.
So if you flash to r36.3, GCID is fixed to 36191598.
