In order to read JetPack version I ran:
cat /etc/nv_tegra_release
and got:
# R32 (release), REVISION: 3.1 …
But according to JetPack archive, there is no such version: R32. Only 32.1
Does it make sense ?
Thank you,
Zvika
and got:
Thank you,
Zvika
No, what you are talking about does not make sense. 32.3.1 indeed a valid version.
32.1 is even older that 32.3.1…
And actually 32.x is “L4T version” not really the jetpack version
A list of L4T releases (which a given JP release is tied to):
https://developer.nvidia.com/linux-tegra
A list of JetPack/SDK Manager releases:
https://developer.nvidia.com/embedded/jetpack-archive
Note that for the more recent releases one can use the most recent JetPack/SDKM and start it with this to see older releases:
sdkmanager --archivedversions
However, if the release is old enough, then the “--archivedversions
” does not work.
I still do not understand:
How can I know what is the JetPack version currently burned on my Xavier ?
The output of /proc/version is: Linux version 4.9.140-tegra … Mon Dec 16 13:32:15 PST 2019
Thank you,
Zvika
You can look up the version of JetPack that corresponds with the version of L4T you are running (from cat /etc/nv_tegra_release
) by searching for the L4T version. For example, googling “L4T R32.3.1” shows that it is JetPack 4.3.
dusty_nv - Thank you very much !
