when i use jetson-interface DIGIDTS train on PC
When I chose the dataset, the web page told me that the folder did not exist, but clearly existed, I did follow the instructions.
[url]jetson-inference/imagenet-training.md at master · dusty-nv/jetson-inference · GitHub
i download pic datasets,and use the imagenet-subset.sh make some file in 12_classes
Then ,i fill the location of 12_classes to digits web page,the web tell me “Floder does not exist”
i dont know, why?
please help me 。thanks
It looks like you meet the similar issue of this one:
[url]https://github.com/NVIDIA/DIGITS/issues/429[/url]
Could you check if the reply inside helps?
yes,same problem.
I want to ask you how to solve the problem mentioned in the following sentence. Now the problem is known, but I don’t know how to solve it. Can you help me? Thank you
Permissions
The DIGITS server runs as www-data, so keep in mind that prebuilt LMDB datasets used for generic models need to be readable by the www-data user. In particular, the entire chain of directories from / to your data must be readable by www-data.
What is your docker run command?
You might want to see this post helps for running the imagenet-subset.sh script inside of your Docker environment:
[url]Cannot Train Data in DIGITS Docker Container · Issue #202 · dusty-nv/jetson-inference · GitHub
