- I use a 5.1.2 sdk downloaded about 2023.8.6.
- yestoday i download the latest version for the older can not use eDP port.
- Before flash mine bootloader, i flash with the code downloaded no modification with device jetson-orin-nano-dev-kit.
- after flash the newest version, eDP can work.
QUESTION: - after the test with downloaded code, i merge the dts modifcation and want to reflash the module.
NOW, I happen the error, and can not reflash…(module or whole device), errors below list:
Entering RCM boot
[ 0.0739 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0739 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0739 ] rcm boot with presigned binaries
[ 0.0779 ] tegrarcm_v2 --instance 1-1 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0804 ] BR_CID: 0x80012344705DD3081000000011000080
[ 0.1159 ] Sending bct_br
[ 0.1268 ] Sending mb1
[ 0.1332 ] Sending psc_bl1
[ 0.1830 ] Sending bct_mb1
[ 0.2485 ] Generating blob for T23x
[ 0.2541 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.2559 ] The number of images in blob is 18
[ 0.2562 ] blobsize is 73339537
[ 0.2564 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 2924608
[ 0.4043 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 0.4049 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 0.4053 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 0.4056 ] Not supported type: mb2_applet
[ 0.4057 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 438768
[ 0.4060 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.4063 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[ 0.4648 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.4652 ] Added binary blob_bpmp_t234-TE980M-A1_prod_sigheader.bin.encrypt of size 1051136
[ 0.4656 ] Added binary blob_tegra234-bpmp-3767-0001-3509-a02_with_odm_sigheader.dtb.encrypt of size 138880
[ 0.4664 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 0.4668 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[ 0.4672 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400864
[ 0.4676 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.4681 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1127568
[ 0.4684 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.4687 ] Added binary blob_boot0.img of size 55525376
[ 0.5797 ] Added binary blob_qskj-orin-nx-dev-0001.dtb of size 347345
[ 0.6711 ] tegrarcm_v2 --instance 1-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.6729 ] BL: version 1.2.0.0-t234-54845784-562369e5 last_boot_error: 0
[ 0.6916 ] Sending bct_mem
[ 0.7034 ] Sending blob
[ 0.8352 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --instance 1-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Cleaning up…
