**• Hardware Platform (Jetson / GPU)**dGPU T4 • DeepStream Version5.0 • JetPack Version (valid for Jetson only) • TensorRT Version7.0
**• NVIDIA GPU Driver Version (valid for GPU only)**440
When running example of Objectdetector_SSD after creating engine segmentation faults occurs but video is seen
deepstream-app -c deepstream_app_config_ssd.txt
Warn: ‘threshold’ parameter has been deprecated. Use ‘pre-cluster-threshold’ instead.
WARNING: …/nvdsinfer/nvdsinfer_func_utils.cpp:34 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
0:00:02.474194751 4563 0x55fabd01f360 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_SSD/sample_ssd_relu6.uff_b1_gpu0_fp32.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT Input 3x300x300
1 OUTPUT kFLOAT NMS 1x100x7
2 OUTPUT kFLOAT NMS_1 1x1x1
ERROR: …/nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: INVALID_ARGUMENT: Cannot find binding of given name: MarkOutput_0
0:00:02.474270324 4563 0x55fabd01f360 WARN nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1545> [UID = 1]: Could not find output layer ‘MarkOutput_0’ in engine
0:00:02.474278026 4563 0x55fabd01f360 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_SSD/sample_ssd_relu6.uff_b1_gpu0_fp32.engine
0:00:02.476900580 4563 0x55fabd01f360 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_SSD/config_infer_primary_ssd.txt sucessfully
Can you provide below info: • Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only)
Using the readme in the object detector SSD folder. Actually before creating the model engine files i.e running for the first time segmentation fault doesnt appear. But after creating engine file and running again the error appears
(gst-plugin-scanner:8553): GStreamer-WARNING **: 13:04:30.412: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtrtserver.so: cannot open shared object file: No such file or directory
0:00:04.694936383 8552 0x55e233094160 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1577> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_SSD/sample_ssd_relu6.uff_b1_gpu0_fp32.engine
0:00:04.695032331 8552 0x55e233094160 WARN nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1545> [UID = 1]: Could not find output layer ‘MarkOutput_0’ in engine
0:00:04.695042338 8552 0x55e233094160 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1681> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_SSD/sample_ssd_relu6.uff_b1_gpu0_fp32.engine
0:00:04.697615006 8552 0x55e233094160 INFO nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/sources/objectDetector_SSD/config_infer_primary_ssd.txt sucessfully
