When the system is under full load, if we first stress the serial port, network port, GPU and memory, and then use the stress command to load all CPU cores, the 1st CPU core will show a load of less than 1% (while all other CPU cores can be loaded above 99%).
Verification steps:
Check with the top and jtop commands. Under this scenario, the load on the 1st CPU core is less than 1%;
Use the stress command to load only all CPU cores independently; all cores can be loaded above 99%.
This issue is reproducible most of the time. Occasionally, the CPU1 utilization in jtop will suddenly spike from very low to a high level, matching that of the other CPU cores, and it appears to return to normal completely. What could be the root cause? I would appreciate any help. Thank you very much.
Retested: one NX and one Nano, iperf3 send/receive on 4 network ports,then stress all the CPU
So why the CPU1 utilization shown in jtop is extremely low?
Why does CPU1 return to normal when iperf3 is stopped and only stress is running?
Nano:
