The L4T is 28.1.
And dmesg as follow
AER: Multiple Uncorrected (Fatal) error received
[code]an 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Initializing cgroup subsys cpuset
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Initializing cgroup subsys cpu
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Initializing cgroup subsys cpuacct
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Linux version 4.4.38-sugey1sensor (root@tegra-ubuntu) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) ) #3 SMP PREEMPT Wed Jun 20 08:03:22 UTC 2018
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Boot CPU: AArch64 Processor [411fd073]
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] bootconsole [uart0] enabled
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] On node 0 totalpages: 2051072
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] DMA zone: 8192 pages used for memmap
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] DMA zone: 0 pages reserved
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] DMA zone: 519408 pages, LIFO batch:31
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Normal zone: 23933 pages used for memmap
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Normal zone: 1531664 pages, LIFO batch:31
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] psci: probing for conduit method from DT.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] psci: PSCIv1.0 detected in firmware.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5cf4000 s31128 r8192 d30312 u69632
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] pcpu-alloc: s31128 r8192 d30312 u69632 alloc=17*4096
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2018947
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0320618012894 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 usbcore.usbfs_memory_mb=1000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Memory: 7972384K/8204288K available (11064K kernel code, 1770K rwdata, 5628K rodata, 1144K init, 679K bss, 166368K reserved, 65536K cma-reserved)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Virtual kernel memory layout:
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9d7c400 ( 125 MB actual)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f5f10000 ( 8031 MB)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] .init : 0xffffffc0010ce000 - 0xffffffc0011ec000 ( 1144 KB)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] .text : 0xffffffc000080000 - 0xffffffc0010ce000 ( 16696 KB)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] .data : 0xffffffc00120d000 - 0xffffffc0013c7a00 ( 1771 KB)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Preemptible hierarchical RCU implementation.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Build-time adjustment of leaf fanout to 64.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] NR_IRQS:64 nr_irqs:64 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] GIC: Using split EOI/Deactivate mode
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.009799] Console: colour dummy device 80x25
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.014456] console [tty0] enabled
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.018011] bootconsole [uart0] disabled
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022112] kmemleak: Kernel memory leak detector disabled
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022123] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022133] pid_max: default: 32768 minimum: 301
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022172] Security Framework initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022199] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022207] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022580] Initializing cgroup subsys freezer
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022591] Initializing cgroup subsys debug
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022722] CPU0 ipc=752
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022729] CPU1 ipc=1024
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022736] CPU2 ipc=1024
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022743] CPU3 ipc=752
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022751] CPU4 ipc=752
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022759] CPU5 ipc=752
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.022789] ASID allocator initialised with 65536 entries
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.046014] tegra-id: chipid=21817.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.046024] tegra-id: opt_subrevision=1.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.046032] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.046624] DTS File Name: /home/vincent/tx2/public_release/sources/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.046642] DTB Build time: May 23 2018 19:38:16
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.062550] CPU1: Booted secondary processor [4e0f0030]
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.074040] CPU2: Booted secondary processor [4e0f0030]
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.085778] CPU3: Booted secondary processor [411fd073]
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.097793] CPU4: Booted secondary processor [411fd073]
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.109815] CPU5: Booted secondary processor [411fd073]
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.109882] Brought up 6 CPUs
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.109936] SMP: Total of 6 processors activated.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.109949] CPU: All CPU(s) started at EL2
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.110403] devtmpfs: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.138057] Initilizing CustomIPI irq domain
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.138272] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.139185] pinctrl core: initialized pinctrl subsystem
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.139356] OS set in device tree is L4T.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.139563] regulator-dummy: no parameters
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.139672] Initializing plugin-manager
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.139735] Plugin module not found
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.140201] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.140548] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.141207] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.142390] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.142735] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.142986] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.143203] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.143991] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.144263] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.144523] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.144815] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.146876] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.148692] Adding domain adsp-pd to PM domain ape-pd
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.151059] NET: Registered protocol family 16
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.151708] console [pstore-1] enabled
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.151721] pstore: Registered ramoops as persistent store backend
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.151734] ramoops: attached 0x200000@0x96080000, ecc: 0/0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.161316] cpuidle: using governor ladder
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.165778] cpuidle: using governor menu
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.166902] bpmp: waiting for handshake
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.166915] bpmp: handshake completed
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.166955] bpmp: synchronizing channels
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.166968] bpmp: channels synchronized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.166978] bpmp: mail init ok
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.167291] vdso: 2 pages (1 code @ ffffffc001215000, 1 data @ ffffffc001214000)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.167323] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.168244] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.169700] tegra_powergate_init: DONE
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.169719] DTS File Name: /home/vincent/tx2/public_release/sources/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.169745] DTB Build time: May 23 2018 19:38:16
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.170744] Tegra reboot handler registered.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.171809] Registering Tegra186 clocks (this may take a while)…done
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.173322] arm-smmu 12000000.iommu: probing hardware configuration…
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.173337] arm-smmu 12000000.iommu: SMMUv2 with:
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.173349] arm-smmu 12000000.iommu: stage 1 translation
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.173361] arm-smmu 12000000.iommu: stage 2 translation
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.173372] arm-smmu 12000000.iommu: nested translation
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.173386] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.173404] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.173422] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.173434] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.173446] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.219087] arm-smmu 12000000.iommu: registered 67 master devices
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.224093] iommu: Adding device 3460000.sdhci to group 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.224942] iommu: Adding device 3400000.sdhci to group 1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.228286] iommu: Adding device 3507000.ahci-sata to group 2
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.228702] iommu: Adding device 3160000.i2c to group 3
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.229099] iommu: Adding device c240000.i2c to group 4
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.229410] iommu: Adding device 3180000.i2c to group 5
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.229744] iommu: Adding device 3190000.i2c to group 6
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.230153] iommu: Adding device 31b0000.i2c to group 7
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.230463] iommu: Adding device 31c0000.i2c to group 8
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.230794] iommu: Adding device c250000.i2c to group 9
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.231118] iommu: Adding device 31e0000.i2c to group 10
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.233048] iommu: Adding device 3210000.spi to group 11
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.233371] iommu: Adding device c260000.spi to group 12
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.233664] iommu: Adding device 3240000.spi to group 13
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.234481] iommu: Adding device 3100000.serial to group 14
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.234859] iommu: Adding device 3110000.serial to group 15
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.235168] iommu: Adding device c280000.serial to group 16
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.235490] iommu: Adding device 3130000.serial to group 17
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.236648] iommu: Adding device 2490000.ether_qos to group 18
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.237241] iommu: Adding device b000000.rtcpu to group 19
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.238024] iommu: Adding device c1a0000.aon to group 20
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.238922] Wake73 for irq=42
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.239228] iommu: Adding device smmu_test to group 21
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.239743] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.239781] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.239843] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.239880] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.239913] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.239945] mc-err: Set intmask: 0xf3140
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.240211] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.241019] Wake76 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.241041] Wake77 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.241059] Wake78 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.241076] Wake79 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.241093] Wake80 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.241110] Wake81 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.241129] Wake82 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.241283] iommu: Adding device 3530000.xhci to group 22
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.241618] iommu: Adding device 3550000.xudc to group 23
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.242435] tegra-pmc c360000.pmc: scratch reg offset dts data not present
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.242463] tegra-pmc: ### PMC reset source: Power on reset
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.242486] tegra-pmc: ### PMC reset level: L0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.242505] tegra-pmc: ### PMC reset status reg: 0x0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.242809] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.242847] tegra-pmc c360000.pmc: IO padctrl driver initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.243020] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.243048] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.243536] iommu: Adding device 13e10000.host1x to group 24
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.243814] iommu: Adding device 13e10000.host1x:ctx0 to group 25
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.244077] iommu: Adding device 13e10000.host1x:ctx1 to group 26
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.244318] iommu: Adding device 13e10000.host1x:ctx2 to group 27
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.244556] iommu: Adding device 13e10000.host1x:ctx3 to group 28
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.244762] iommu: Adding device 13e10000.host1x:ctx4 to group 29
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.244992] iommu: Adding device 13e10000.host1x:ctx5 to group 30
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.245212] iommu: Adding device 13e10000.host1x:ctx6 to group 31
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.245503] iommu: Adding device 13e10000.host1x:ctx7 to group 32
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.245898] iommu: Adding device 150c0000.nvcsi to group 33
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.246466] iommu: Adding device 15700000.vi to group 34
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.246804] iommu: Adding device 15600000.isp to group 35
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.247108] iommu: Adding device 15210000.nvdisplay to group 36
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.247346] iommu: Adding device 15340000.vic to group 37
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.247589] iommu: Adding device 154c0000.nvenc to group 38
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.247783] iommu: Adding device 15480000.nvdec to group 39
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.248114] iommu: Adding device 15380000.nvjpg to group 40
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.248339] iommu: Adding device 15500000.tsec to group 41
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.248577] iommu: Adding device 15100000.tsecb to group 42
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.249242] iommu: Adding device 15810000.se to group 43
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.249466] iommu: Adding device 15820000.se to group 44
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.249690] iommu: Adding device 15830000.se to group 45
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.249874] iommu: Adding device 15840000.se to group 46
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.250365] iommu: Adding device 17000000.gp10b to group 47
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.251766] tegra-reset 5000000.clock: registered 193 resets.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.253681] iommu: Adding device d000000.bpmp to group 48
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.253950] bpmp: ping status is 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.254157] bpmp d000000.bpmp: firmware tag is 0705d30e2bb4ef1fcf63b70c5fc3deef
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.254515] bpmp d000000.bpmp: probe ok
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.256946] iommu: Adding device 2600000.dma to group 49
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.257731] GPIO line 461 (cam0-rst) hogged as output/low
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.257863] GPIO line 456 (cam0-pwdn) hogged as output/low
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.257935] GPIO line 457 (cam1-rst) hogged as output/low
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.257984] GPIO line 426 (cam1-pwdn) hogged as output/low
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.258036] GPIO line 424 (wifi-enable) hogged as output/high
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.258087] GPIO line 445 (sdmmc-wake-input) hogged as input
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.258138] GPIO line 446 (sdmmc-wake-output) hogged as output/low
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.258244] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.260156] GPIO line 315 (wifi-wake-ap) hogged as input
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.260271] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.261155] iommu: Adding device 10003000.pcie-controller to group 50
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.261456] iommu: Adding device sound to group 51
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.263094] iommu: Adding device 3510000.hda to group 52
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.264138] iommu: Adding device adsp_audio to group 53
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.265471] iommu: Adding device 2993000.adsp to group 54
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.275218] vdd-ac-bat: 5000 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.277661] vdd-1v8-ap: 1800 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.278853] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.279195] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.296490] SCSI subsystem initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.296665] libata version 3.00 loaded.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.296833] usbcore: registered new interface driver usbfs
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.296894] usbcore: registered new interface driver hub
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.296999] usbcore: registered new device driver usb
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.299946] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.300385] pca953x 0-0074: failed reading register
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.300459] pca953x: probe of 0-0074 failed with error -121
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.300818] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.301249] pca953x 0-0077: failed reading register
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.301320] pca953x: probe of 0-0077 failed with error -121
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.313400] media: Linux media interface: v0.10
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.313488] Linux video capture interface: v2.00
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.317533] pps_core: LinuxPPS API ver. 1 registered
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.317578] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.317628] PTP clock support registered
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.318640] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.318703] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.320186] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.322166] GPIO line 253 (spmic_gpio_input_5) hogged as input
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.322352] GPIO line 254 (spmic_gpio_input_6) hogged as input
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.322448] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.330724] vddio-ddr: at 1125 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.334561] avdd_dsi_csi: 1200 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.338565] vdd-1v8: 1800 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.342560] vdd-3v3-sys: 3300 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.343653] spmic-ldo0: at 1800 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.344481] spmic-ldo1: at 800 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.350559] vddio-3v3: 3300 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.351168] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.353784] vdd-rtc: at 800 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.354453] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.357785] spmic-ldo6: at 1500 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.361782] vdd-pex-1v05: 1000 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.362327] dvdd-pex: 1000 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.362583] max77620 4-003c: max77620 probe successful
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.362834] Advanced Linux Sound Architecture Driver Initialized.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.366237] en-vdd-sd: 3300 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.369801] vdd-hdmi-bj1: 5000 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.369969] vdd-usb0-5v: 5000 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.370127] vdd-usb1-5v: 5000 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.370480] vdd-3v3: 3300 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.370612] en-vdd-vcm-2v8: 2800 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.370752] vdd-sys-bl: 3300 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.370909] vdd-led-pr0: 1800 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.371100] vdd-usb-hub: 5000 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.371258] vdd-hdmi-bj1-v0: 5000 mV
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.372929] gpio tegra-gpio wake53 for gpio=159(X:7)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.374596] extcon-gpio-states external-connection:extcon@1: Cable state 2
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.374977] clocksource: Switched to clocksource arch_sys_counter
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.393505] nvmap_heap_init: nvmap_heap_init: created heap block cache
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.393784] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.394260] nvmap_page_pool_init: Total RAM pages: 2009480
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.394275] nvmap_page_pool_init: nvmap page pool size: 251185 pages (981 MB)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.394465] nvmap_background_zero_thread: PP zeroing thread starting.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.398774] Wake76 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.398786] Wake77 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.398795] Wake78 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.398805] Wake79 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.398813] Wake80 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.398822] Wake81 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.398831] Wake82 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.399557] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.399742] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.399851] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.399928] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.400289] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.400425] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.400561] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.400701] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.400989] isomgr_init(): iso emc max clk=1866000KHz
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.401000] isomgr_init(): max_iso_bw=26870400KB
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.401072] NET: Registered protocol family 2
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.401403] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.401600] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.401893] TCP: Hash tables configured (established 65536 bind 65536)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.401946] UDP hash table entries: 4096 (order: 5, 131072 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.402004] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.402165] NET: Registered protocol family 1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.402339] RPC: Registered named UNIX socket transport module.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.402353] RPC: Registered udp transport module.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.402363] RPC: Registered tcp transport module.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.402373] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.402391] PCI: CLS 0 bytes, default 128
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.402482] Trying to unpack rootfs image as initramfs…
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.415920] host1x 13e10000.host1x: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.416703] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.418770] futex hash table entries: 2048 (order: 6, 262144 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.418859] audit: initializing netlink subsys (disabled)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.418899] audit: type=2000 audit(0.404:1): initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.425117] io scheduler noop registered (default)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.427991] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.429156] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.430188] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.431215] tegra-pwm c340000.pwm: PWM clk can sleep in ops
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.434528] tsec 15500000.tsec: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.435628] tsec 15100000.tsecb: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.437686] nvdec 15480000.nvdec: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.441086] falcon 15340000.vic: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.442102] falcon 154c0000.nvenc: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.443104] falcon 15380000.nvjpg: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.443795] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.444294] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.444788] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.445283] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.445776] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.446268] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.446766] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.447276] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.448530] DC OR NODE connected to /host1x/sor1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.448698] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.448746] tegradc 15210000.nvdisplay: DT parsed successfully
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.448789] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.448792] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.448796] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.456232] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.456441] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.456458] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.456474] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.456516] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.456530] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.458004] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.458679] kfuse 3830000.kfuse: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.458991] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.459011] PD DISP0 index2 UP
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.459862] PD DISP1 index3 UP
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.459865] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.460037] PD DISP2 index4 UP
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.460238] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.462069] console [ttyS0] disabled
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.462119] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.486274] Unsupported HDMI VIC 64, ignoring
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.486285] PD DISP2 index4 DOWN
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.486441] PD DISP1 index3 DOWN
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.486589] PD DISP0 index2 DOWN
Jan 26 07:07:21 tegra-ubuntu kernel: [ 0.488560] tegradc 15210000.nvdisplay: probed
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.499302] console [ttyS0] enabled
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.501195] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.502252] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.502477] serial-tegra 3130000.serial: RX in PIO mode
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.503336] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.508865] Console: switching to colour frame buffer device 240x75
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.513566] brd: module loaded
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.517892] loop: module loaded
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.518094] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.518111] nct1008_nct72 7-004c: find device tree node, parsing dt
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.518115] nct1008_nct72 7-004c: starting parse dt
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.518196] nct1008_nct72 7-004c: success parsing dt
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.518306] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.593233] tegradc 15210000.nvdisplay: fb registered
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.598584] gpio tegra-gpio wake21 for gpio=121(P:1)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.603824] PD DISP0 index2 UP
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.605375] gk20a 17000000.gp10b: failed to allocate secure buffer -12
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.614729] PD DISP1 index3 UP
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.615863] tmp451: Enabled overheat logging at 104.00C
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.615932] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.615961] nct1008_nct72 7-004c: nct1008_probe: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618017] THERMAL EST: found 3 subdevs
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618019] THERMAL EST num_resources: 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618022] [THERMAL EST subdev 0]
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618025] [THERMAL EST subdev 1]
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618028] [THERMAL EST subdev 2]
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618221] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618223] THERMAL EST: thz register success.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618293] THERMAL EST: end of probe, return err: 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618450] tegra_profiler: Branch: Dev
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618452] tegra_profiler: Version: 1.109
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618453] tegra_profiler: Samples version: 37
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618454] tegra_profiler: IO version: 21
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618457] armv8_pmu: imp: 0x41, idcode: 0x1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618460] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618462] armv8_pmu: imp: 0x4e, idcode: 0x1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618464] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618466] armv8_pmu: imp: 0x4e, idcode: 0x1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618467] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618469] armv8_pmu: imp: 0x41, idcode: 0x1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618471] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618473] armv8_pmu: imp: 0x41, idcode: 0x1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618474] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618476] armv8_pmu: imp: 0x41, idcode: 0x1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618478] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.618597] tegra_profiler: auth: init
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.621200] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.621206] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.621815] scsi host0: tegra_ahci
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.622022] scsi host1: tegra_ahci
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.622134] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.622136] ata2: DUMMY
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.622827] spi-tegra114 3210000.spi: Static pin configuration used
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.623186] spi-tegra114 c260000.spi: Static pin configuration used
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.623490] spi-tegra114 3240000.spi: Static pin configuration used
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.624077] tun: Universal TUN/TAP device driver, 1.6
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.624078] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.624199] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.624201] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.624229] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.624230] igb: Copyright (c) 2007-2014 Intel Corporation.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.624958] PPP generic driver version 2.4.2
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625058] PPP BSD Compression module registered
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625063] PPP Deflate Compression module registered
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625077] PPP MPPE Compression module registered
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625086] NET: Registered protocol family 24
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625122] usbcore: registered new interface driver r8152
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625150] usbcore: registered new interface driver asix
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625171] usbcore: registered new interface driver ax88179_178a
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625194] usbcore: registered new interface driver cdc_ether
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625220] usbcore: registered new interface driver smsc95xx
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625240] usbcore: registered new interface driver net1080
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625261] usbcore: registered new interface driver cdc_subset
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625281] usbcore: registered new interface driver zaurus
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625317] usbcore: registered new interface driver cdc_ncm
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625500] Wake76 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625501] Wake77 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625502] Wake78 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625503] Wake79 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625504] Wake80 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625505] Wake81 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625506] Wake82 for irq=199
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625547] tegra-xotg xotg: usb2 phy is not available yet
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.625963] usbcore: registered new interface driver usb-storage
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.626011] usbcore: registered new interface driver usbserial
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.626032] usbcore: registered new interface driver ftdi_sio
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.626047] usbserial: USB Serial support registered for FTDI USB Serial Device
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.626067] usbcore: registered new interface driver option
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.626080] usbserial: USB Serial support registered for GSM modem (1-port)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.626099] usbcore: registered new interface driver pl2303
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.626111] usbserial: USB Serial support registered for pl2303
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.626256] tegra-usb-cd usb_cd: otg phy is not available yet
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.628079] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b a8 3f e8
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.628533] libphy: dwc_phy: probed
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.628903] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.691994] gpio tegra-gpio wake18 for gpio=101(M:5)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.692136] bcm54xx_low_power_mode(): put phy in iddq-lp mode
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.756624] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.758616] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.758628] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.758756] i2c /dev entries driver
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.759505] gspca_main: v2.14.0 registered
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.759541] usbcore: registered new interface driver gspca_zc3xx
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.759779] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.761483] FAN: coudln’t get the regulator
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.762144] device-mapper: uevent: version 1.0.3
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.762301] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.762609] sdhci: Secure Digital Host Controller Interface driver
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.762610] sdhci: Copyright(c) Pierre Ossman
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.762614] sdhci-pltfm: SDHCI platform and OF driver helper
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.762866] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.763154] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.763395] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.763835] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.763955] hidraw: raw HID events driver (C) Jiri Kosina
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.765350] usbcore: registered new interface driver usbhid
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.765352] usbhid: USB HID core driver
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.767370] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.767897] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.768046] ina3221x: probe of 0-0042 failed with error -121
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.768458] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.769080] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.769196] ina3221x: probe of 0-0043 failed with error -121
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.769673] nvadsp 2993000.adsp: in probe()…
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.771019] nvadsp 2993000.adsp: Registering AMC Error Interrupt
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.771057] nvadsp 2993000.adsp: AMC/ARAM initialized.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.771287] nvadsp 2993000.adsp: nvadsp_app_module_probe
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.778408] Denver: backdoor interface is NOT available.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.780520] coresight-tmc 8030000.etf: TMC initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.792343] coresight-tmc 8050000.etr: TMC initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.792823] coresight-tpiu 8060000.tpiu: TPIU initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.793418] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.793935] coresight-funnel 8010000.funnel_major: FUNNEL initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.794427] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.794902] coresight-replicator 8040000.replicator: REPLICATOR initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.795621] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.796259] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.796869] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.797493] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.797521] Module initialized successfully
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.801304] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.802847] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.803113] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.803469] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.803520] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.803559] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.803597] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.803637] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.803674] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.803714] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.803850] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.803853] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.804530] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.804533] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.804536] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.804539] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.804541] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.804543] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.804546] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.804573] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.806982] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.807309] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.807614] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.812050] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.812861] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.813007] camchar: rtcpu character device driver loaded
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.817076] tegra186-aondbg aondbg: aondbg driver probe() OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.817372] register_ari_mca_banks: Registered MCA ROC:IOB
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.817518] register_ari_mca_banks: Registered MCA ROC:CCE
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.817964] tegra18-bridge 2390000.axi2apb: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.817995] tegra18-bridge 23a0000.axi2apb: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818020] tegra18-bridge 23b0000.axi2apb: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818044] tegra18-bridge 23c0000.axi2apb: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818067] tegra18-bridge 23d0000.axi2apb: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818092] tegra18-bridge 2100000.axip2p: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818116] tegra18-bridge 2110000.axip2p: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818139] tegra18-bridge 2120000.axip2p: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818162] tegra18-bridge 2130000.axip2p: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818187] tegra18-bridge 2140000.axip2p: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818210] tegra18-bridge 2150000.axip2p: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818235] tegra18-bridge 2160000.axip2p: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818259] tegra18-bridge 2170000.axip2p: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818284] tegra18-bridge 2180000.axip2p: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818307] tegra18-bridge 2190000.axip2p: bridge probed OK
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818355] **** A57 ECC: Enabled
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818357] tegra18_a57_serr_init: on CPU 5 a A57 Core
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818491] parse_throttle_dt_data: Num cap clks = 4
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818494] parse_throttle_dt_data: clk=mcpu type=1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818497] parse_throttle_dt_data: clk=bcpu type=2
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818504] parse_throttle_dt_data: clk=gpu type=4
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.818506] parse_throttle_dt_data: clk=emc type=3
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.819054] tegra_throttle_probe: probe successful. #cdevs=4
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.819145] tegra18x_actmon d230000.actmon: in actmon_register()…
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.822257] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.822549] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.850961] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.851222] sdhci-tegra 3400000.sdhci: Got CD GPIO
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.851322] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.851356] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.851593] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.880953] mmc0: MAN_BKOPS_EN bit is not set
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.888192] mmc0: Skipping tuning since strobe enabled
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.891001] gpio tegra-gpio wake71 for gpio=125(P:5)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.891035] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.895631] mmc0: periodic cache flush enabled
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.895638] mmc0: new HS400 MMC card at address 0001
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.895887] mmcblk0: mmc0:0001 032G34 29.1 GiB
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.895993] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.896090] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.896182] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.897287] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.942988] ata1: SATA link down (SStatus 0 SControl 300)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 2.943428] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141139] mmc1 tuning done saved tap delay=64
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141143] mmc1: hw tuning done …
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141150] mmc1: tuning_window[0]: 0xffffffff
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141156] mmc1: tuning_window[1]: 0xfffff1ff
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141162] mmc1: tuning_window[2]: 0xfe3fffff
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141193] mmc1: tuning_window[3]: 0x7fffffff
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141199] mmc1: tuning_window[4]: 0x0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141204] mmc1: tuning_window[5]: 0x0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141209] mmc1: tuning_window[6]: 0x0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141214] mmc1: tuning_window[7]: 0x0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141219] sdhci: Tap value: 64 | Trim value: 5
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.141223] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.147522] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
Jan 26 07:07:21 tegra-ubuntu kernel: [ 3.147568] mmc1: new ultra high speed SDR104 SDIO card at address 0001
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.157819] PD DISP2 index4 UP
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.164100] Parent Clock set for DC plld2
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.173241] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_200M
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.182887] tegradc 15210000.nvdisplay: hdmi: pclk:154128K, set prod-setting:prod_c_300M
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.210731] tegra-se-nvhost 15810000.se: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.217620] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.225557] tegra-se-nvhost 15820000.se: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.232311] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.240152] tegra-se-nvhost 15830000.se: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.246658] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.254469] tegra-se-nvhost 15840000.se: initialized
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.261129] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.271879] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.283509] cpufreq: platform driver Initialization: pass
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.290214] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.297844] tegra_cluster_clk e090000.cluster_clk_priv: passed
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.305014] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.315669] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.325992] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ea896
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.333030] Unsupported HDMI VIC 64, ignoring
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.339579] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.340921] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.342479] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.345053] cpuidle: Initializing cpuidle driver init for Denver cluster
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.345204] cpuidle: Initializing cpuidle driver init for A57 cluster
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.346390] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.346394] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.350037] tegra210_adsp_audio_platform_probe: platform probe started
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.362236] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.362941] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.364344] tegra210-adsp adsp_audio: Default param-type to BYTE for src
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.364866] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.365359] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.365365] tegra210-adsp adsp_audio: adma channel page address dt entry not found
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.365368] tegra210-adsp adsp_audio: using adma channel page 0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.366322] tegra210_adsp_audio_platform_probe probe successfull.
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.366323] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.366528] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.378500] OPE platform probe
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.378603] OPE platform probe successful
Jan 26 07:07:21 tegra-ubuntu kernel: [ 4.395386] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
