Where can I get the DRIVE AGX Orin cross-compiler toolchian?
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
I want to compile my source codes in my windows machine to generate binary executable file for Orin. Where can I find or download the corresponding toolchain?
Please consult the following documents for information on the sample and cross-compilation:
We don’t have cross compile toolchain based on windows. You need to use linux host machine.
Please see Build and Run Sample Applications for DRIVE OS 6.x Linux | NVIDIA Docs
Okay. That means the convenient way for cross-compilation is to install dirve OS docker container on my linux host machine and utilize the cross-compiler of the SDK?
If i only want to compile my own project. Can i just download the compiler as here described for cross-compilation?
NVIDIA Supported Cross Toolchains | NVIDIA Docs
Yes. We recommend to use docker container for cross compiling the application as it has all needed libs/headers/toolchain
