I cannot find a way that works to install jetpack on ubuntu 22.04. Whats the deal?
So I have attempted to add the repos as per documentation. This fails.
I have attempted to install the .dep this fails also due to deps that are unsolvable.
root@X570S:/home/user/Downloads# dpkg -i sdkmanager_2.2.0-12028_amd64.deb
Selecting previously unselected package sdkmanager.
(Reading database ... 151680 files and directories currently installed.)
Preparing to unpack sdkmanager_2.2.0-12028_amd64.deb ...
Unpacking sdkmanager (2.2.0-12028) ...
dpkg: dependency problems prevent configuration of sdkmanager:
sdkmanager depends on libcanberra-gtk-module; however:
Package libcanberra-gtk-module is not installed.
dpkg: error processing package sdkmanager (--install):
dependency problems - leaving unconfigured
Processing triggers for gnome-menus (3.36.0-1.1ubuntu3) ...
Processing triggers for desktop-file-utils (0.27-2build1) ...
Processing triggers for hicolor-icon-theme (0.18-1) ...
Errors were encountered while processing:
sdkmanager
Whats the word on this mess?
Installing the sdk was once the easy part!
When you see a message like this:
Try to add that to the host PC. Example:
sudo apt-get install libcanberra-gtk-module
Sometimes you’ll want to first update the host itself with:
# Takes a snapshot of this release's current package versions:
sudo apt update
# Updates to that snapshot of release versions.
sudo apt-get upgrade
# Typically this is where new packages are added since the snapshot is up to date.
Basically, if you have a missing dependency, you add that dependency and then try again with sdkmanager install.
As stated libcanberra-gtk-module` was not avalable for install a search confirmed this. I did attempt to manually install a verision of libcanberra-gtk-module but this was not accepted bu the sdk dep either. I than attempted to add the repos that also failed. I dont recall the errors but I believe that they were unverifiable. I dont recall as i am not a regular ubuntu user.
I really would like a way to add the nvidia jetson repos that works so that I am not stuck searching around for all the poorly documented dependencies.
I don’t know the specific packages, but could you attach a copy of your /etc/apt/sources.list? There are other places in sources.list.d that might add to this, but I think the universe repo is used for this package. Is it correct that you are installing this on the host PC? I only ask because sometimes people have tried to install directly to the Jetson (not often, but it happens).
Does anyone else know more about libcanberra-gtk-module?
I will have to try the earlier version of Ubuntu that is listed, but realized with my other obligations that this problem is a low priority at the moment.
Thank You for attempting to help! It is appreciated.
